2002  2003  2004  <20052006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 2002  2003  2004  <20052006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: CA V4 Protocol Specification
To: [email protected]
Date: Sun, 30 Oct 2005 13:56:08 +0100
On Wednesday 26 October 2005 00:33, Jeff Hill wrote:
> Attached is a rough cut at the EPICS V4 CA protocol specification.
Hi Jeff,
one more comment about a feature of the new protocol that makes me feel
quite uneasy. This issue also provoked the first and longest remark in
the Design Notes.
It may be that I haven't got the whole picture yet, but I think it is
not acceptable to leave client applications in the dark about whether a
channel connection request could be honored or not, for however short a
time span. To qualify this as an "unfortunate drawback" doesn't quite
capture it, AFAICS, and to say that "brief windows of uncertainty are
not unreasonable" is, I think, wrong, if I may be so forward. This goes
even /if/ you'd somehow manage to give strict timing guarantees for
exception responses, which, AFAIK, are impossible to give, considering
that ethernet-based networks are by construction not hard-real-time
capable.
I wonder what clients are supposed to do after 'defining' a channel.
Should they wait for NNN seconds after each such request, hoping they
will be connected if they don't receive an exception until then? Or
should they just start sending IO requests, hoping that the channel has
connected?
Or, and this deems me as the most probable outcome, clients will
routinely check that a channel has connected, namely by first issuing a
suitable IO request (for instance a read) immediately after the channel
connection request. If and when they receive a valid response, they
know the channel is connected and only then start issuing the 'real'
requests they want to send. Note that forcing clients to use such a
'hack' will /increase/ network load instead of reducing it.
Ben
CA V4 Protocol Specification Jeff Hill
Prev: Re: CA V4 Protocol Specification Benjamin Franksen
Next: RE: V4 database definition files Rees, NP (Nick)
Index: 2002  2003  2004  <20052006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Next: V4 database definition files Rees, NP (Nick)
