2002  2003  2004  <20052006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 2002  2003  2004  <20052006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: R3.14.8 testing
To: [email protected]
Date: Tue, 01 Nov 2005 08:03:09 -0600
I successfully ran mrkHwdTest
I also succesfully ran mrkSoftTest
a) All test that can be run on vxWorks (68040 processors)
b) All tests that can have a combination on a solaris and a linux ioc
Janet also asked me to try testing for sparc64, i.e. with EPICS_HOST_ARCH=solaris-sparc64.
I get many many warning messages like:
/opt/SUNWspro/bin/CC -c -D_POSIX_C_SOURCE=199506L -D_XOPEN_SOURCE=500 -DUNIX -DSOLARIS=9 -mt -D__EXTENSIONS__ -O +w -xtarget=ultra -xarch=v9 -xtarget=ultra -xarch=v9 -KPIC -I. -I.. -I../../../include/os/solaris -I../../../include ../dbSubscriptionIO.cpp "../../../include/epicsTime.h", line 328: Warning: Conversion of 64 bit type value to "unsigned" causes truncation. "../../../include/epicsTime.h", line 329: Warning: Conversion of 64 bit type value to "unsigned" causes truncation.
2 Warning(s) detected.
I succssfully ran a couple of tests in mrkSoftTest.
HOWEVER the example application crashes.
I determined that it was related to
record(compress,"$(user):compressExample")
       field(DESC, "Circular buffer")
       field(INP,"$(user):aiExample.VAL CP NMS")
       field(ALG,"Circular Buffer")
       field(NSAM,"10")
       field(HOPR,"10")
       field(EGU,"Counts")
That is the CP input link.
dbCa got the callbacks from channel access for connection and initial values and returned.
After that the crash occured but I did not pursue it further.
Is it worth pursuing further for release 3.14.8?
Sounds like it may take some real work to be ready for full 64 bit architectures.
Marty
RE: R3.14.8 testing Jeff Hill
Prev: RE: V4 database definition files Rees, NP (Nick)
Next: RE: R3.14.8 testing Jeff Hill
Index: 2002  2003  2004  <20052006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: XML include, Re: V4 database definition files Kay-Uwe Kasemir
