I did a cvs update and rebuild.
exampleApp still crashes.
There are still lots of warning messages like
/fdmgr/fdmgr.cpp
"../../../src/libCom/fdmgr/fdManager.h", line 171: Warning: Conversion
of 64 bit type value to "const unsigned" causes truncation.
"../../../src/libCom/fdmgr/fdmgr.cpp", line 33: Warning: Conversion of
I think we should create 3.14.8 and take care of this later.
I am concerned that fixing the 64 bit problems will in turn cause new bugs.
Marty
Jeff Hill wrote:
I get many many warning messages like:
"../../../include/epicsTime.h", line 328: Warning: Conversion of 64 bit
type value to "unsigned" causes truncation.
This is because the epicsTime has a 64 bit unsigned seconds field and the
network time stamp has a 32 bit unsigned seconds' field. I committed a fix
(which just suppresses the warning allowing truncation by design to
continue). Here is the comment in the source code.
// epicsTime::secPastEpoch is based on ulong and has much greater range
// on 64 bit hosts than the orginal epicsTimeStamp::secPastEpoch. The
// epicsTimeStamp::secPastEpoch is based on epicsUInt32 so that it will
// match the original network protocol. Of course one can anticipate
// that eventually, a epicsUInt64 based network time stamp will be
// introduced when 64 bit architectures are more ubiquitous.
// Truncation usually works fine here because the routines in this code
// that compute time stamp differences and compare time stamps produce
// good results when the operands are on either side of a time stamp
// rollover as long as the difference between the operands does
// not exceed 1/2 of full range.
- Re: R3.14.8 testing Ernest L. Williams Jr.
- RE: R3.14.8 testing Jeff Hill
Re: XML include, Re: V4 database definition files anj
<2005>
2025
2026
<2005>
2025
2026
