Your fix works perfectly.
HP-UX returns:
creek: .../base/3-14-X > bin/hpux-parisc/blockingSockTestHost
../blockingSockTest.cpp: server circuit was disconnected
../blockingSockTest.cpp: client circuit socket recv() error was
"Interrupted system call"
The local OS behaves like "esscimqi_socketSigAlarmRequired".
The epicsSocketSystemCallInterruptMechanismQuery() function returns
while my Linux box says:
aragon: .../base/3-14-X > bin/linux-x86/blockingSockTestHost
../blockingSockTest.cpp: client circuit was disconnected
The local OS behaves like "esscimqi_socketBothShutdownRequired".
which is quite what I would expect these two to return.
Thanks!
Ralph
Jeff Hill wrote:
Ralph,
This test isnt quite the same as the others as it is documenting differences
between the various OS implementations of sockets and testing how well we
are able to deal with them.
That test was written to document what is required to interrupt a thread
blocking in socket recv() on the various OS. It looks like the code was
presuming that a CA server was running on the local host, and would not work
otherwise. There is also code there to startup a local server. I went ahead
and instantiated that code and committed it. The test should run standalone
now.
Nevertheless...
O strange behavior could result if a CA server is already running on the
local host when the test starts.
O strange behavior could result if the local os does not allow the process
to exit if a thread is stil running when main exists (I didn't see any
problems with this on linux or windows).
Jeff
- RE: 3.14.8: blockingSockTest - assert() fails. Jeff Hill
RE: R3.14.8 testing Jeff Hill
Re: 3.14.8@Linux: OSS priorities problem? Ralph Lange
<2005>
2025
2026
More testing on linux-x86_64 Ernest L. Williams Jr.
<2005>
2025
2026
