2002  2003  2004  <2005>  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 2002  2003  2004  <2005>  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: R3.14.8/logClient
To: [email protected]
Date: Tue, 15 Nov 2005 14:03:31 +0100
Hello,
I am in the process of porting CaPutLog [1] to R3.14 and noticed that
the implementation relies on an almost identical copy of the R3.13
logClient library (part of libCom). I further noticed that the
logClient in R3.14 is *almost* fit to be re-used for CaPutLog. I have
made some rather superficial changes to logClient.[ch] that would
enable such a re-use. The only change in the interface is an additional
extended initialization routine
epicsShareFunc logClientId epicsShareAPI logClientInitExt (
    struct in_addr server_addr, unsigned short server_port);
that enables creation of a client that send messages to a different
server. Additionally, this init routine does /not/ automatically
register with the errlog library, i.e. it does not call
errlogAddListener.
Since all existing routines remain unchanged, this change would be
completely backward compatible.
Are there any chances to get this into R3.14.8? If yes, to whom should I
send the patches?
[1] http://www-kryo.desy.de/documents/EPICS/DESY/EpicsLog/CAPutLog.html
Ben
Re: R3.14.8/logClient Marty Kraimer
Prev: Re: mrkSoftTest doesn't compile Marty Kraimer
Next: Re: R3.14.8/logClient Marty Kraimer
Index: 2002  2003  2004  <2005>  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: RE: online_notify.c Jeff Hill
