2002  2003  2004  <2005>  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 2002  2003  2004  <2005>  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: crash when exiting running softIOC as root
To: EPICS Core-Talk <[email protected]>
Date: Thu, 17 Nov 2005 12:59:46 -0500
crash when exiting running softIOC as root on the linux-x86_64
architecture.  linux-x86 behaves perfect when exiting.
Any ideas.  Below is a stack trace:
[root@dragon iocamd64]# gdb ../../bin/linux-x86_64/amd64 core.23554
GNU gdb Red Hat Linux (6.3.0.0-1.63rh)
(gdb) bt
#0  0x000000388fb2e37d in raise () from /lib64/tls/libc.so.6
#1  0x000000388fb2faae in abort () from /lib64/tls/libc.so.6
#2  0x000000389080ab11 in unwind_cleanup ()
from /lib64/tls/libpthread.so.0
#3  0x0000002a9634e5ae in ca_pend_event (timeout=Variable "timeout" is
not available.
) at ../access.cpp:458
#4  0x0000002a957698a1 in caSystem::pend (this=0x5d8400, seconds=10,
wait=1)
    at ../pvCa.cc:130
#5  0x0000002a9565fb27 in seqAuxThread (tArgs=Variable "tArgs" is not
available.
) at ../seq_task.c:626
#6  0x0000002a964b9410 in start_routine (arg=Variable "arg" is not
available.
    at ../../../src/libCom/osi/os/posix/osdThread.c:316
#7  0x00000038908060aa in start_thread ()
#8  0x000000388fbc5b43 in clone () from /lib64/tls/libc.so.6
#9  0x0000000000000000 in ?? ()
(gdb)
Ernest
Prev: RE: dbEvent.c line 665 Jeff Hill
Next: Re: R3.14.8 Status/logClient patch Benjamin Franksen
Index: 2002  2003  2004  <2005>  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: [Fwd: RE: Patches to support linux-arm for EPICS base] Andrew Johnson
Next: posix thread priorities Jeff Hill
