2002  2003  2004  <20052006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 2002  2003  2004  <20052006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: epicsThreadSetPriority called by non epics thread
To: Jeff Hill <[email protected]>
Cc: "'Marty Kraimer'" <[email protected]>, [email protected]
Date: Thu, 17 Nov 2005 17:16:36 -0600
Jeff Hill wrote:
One has to configure the build setting "USE_POSIX_THREAD_PRIORITY_SCHEDULING
= YES" on Linux in order to see these messages occurring whenever a client
connects.
Interesting - with that setting I can replicate this on our 2-processor linux server (saturn) but not on my 1-processor linux workstation (apsajnt). I noticed that Jeff was running on an SMP kernel, and I assume his machine has more than one CPU:
Linux version 2.4.21-20.ELsmp ([email protected]) (gcc
version 3.2.3 20030502 (Red Hat Linux 3.2.3-42)) #1 SMP Wed Aug 18 20:46:40
EDT 2004
My boxes look like this:
saturn% cat /proc/version
Linux version 2.4.20-28.8smp ([email protected]) (gcc version 3.2 20020903 (Red Hat Linux 8.0 3.2-7)) #1 SMP Thu Dec 18 12:25:21 EST 2003
apsajnt% cat /proc/version
Linux version 2.4.20-19.9 ([email protected]) (gcc version 3.2.2 20030222 (Red Hat Linux 3.2.2-5)) #1 Tue Jul 15 17:18:13 EDT 2003
Looking at the code in libCom/osi/os/posix/osdThread.c I can now see the problem and explain why it's only happening on SMP systems.
This code is from epicsThreadCreate():
    pthreadInfo = init_threadInfo(name,priority,stackSize,funptr,parm);
    if(pthreadInfo==0) return 0;
    pthreadInfo->isEpicsThread = 1;
    setSchedulingPolicy(pthreadInfo,SCHED_FIFO);
    status = pthread_create(&pthreadInfo->tid,&pthreadInfo->attr,
                start_routine,pthreadInfo);
    if(status==EPERM){
pthreadInfo = init_threadInfo(name,priority,stackSize,funptr, parm);
The code creates a threadInfo object and calls setSchedulingPolicy(). If the subsequent pthread_create() call fails with an EPERM, it tries again without the setSchedulingPolicy(). There are two problems with this: a memory leak, since it never frees the original threadInfo object, and it doesn't set the isEpicsThread flag on the retry. My conjecture is that on an SMP linux kernel pthread_create() does actually return EPERM if the user isn't root, whereas on my single processor (UP) kernel it just accepts (and probably ignores) the thread priority request without error. I have tried running the IOC as root on my workstation, and epicsThreadShowAll lists all the threads with a zero for OSSPRI so it seems that the UP kernel completely ignores the thread priority. Unfortunately I don't have the ability to run the IOC as root on the SMP system, so I can't confirm my guess that way.
I have committed a fix to the second problem (forgetting to set the isEpicsThread flag) which removes the messages Jeff was seeing, but the memory leak is harder to fix since the free_threadInfo() routine tries to remove the threadInfo object from a list which it hasn't been added to yet. From the CVS history I see that Marty has already reworked this section of code a bit; I'm going to leave it for him to decide how to fix (there's a FIXME: comment at the relevent line).
- Andrew
* * Matt Santos / / Leo McGarry * * For a Brighter America * *
RE: epicsThreadSetPriority called by non epics thread Jeff Hill
Re: epicsThreadSetPriority called by non epics thread Marty Kraimer
Prev: Re: multiple error messages Andrew Johnson
Next: linux-x86_64 issue: epicsThread: Unknown C++ exception in thread "timerQueue" Ernest L. Williams Jr.
Index: 2002  2003  2004  <20052006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: RE: epicsThreadSetPriority called by non epics thread Jeff Hill
Next: RE: epicsThreadSetPriority called by non epics thread Jeff Hill
