2002  2003  2004  <20052006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 2002  2003  2004  <20052006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: posix thread priorities
To: Jeff Hill <[email protected]>
Date: Fri, 18 Nov 2005 11:42:17 +0100
Jeff,
wasn't it that you had to be running the soft IOC as root on Linux to see the OS priorities?
Ralph
Jeff Hill wrote:
Pursuing this a bit further, I notice, using epicsThreadShowAll, that the
OSI => OSD priority mapping maybe isn't working on POSIX (the OSSPRI column
is always zero)?
Again, this is building with USE_POSIX_THREAD_PRIORITY_SCHEDULING = YES.
Jeff
epics> epicsThreadShowAll
           NAME     EPICS ID   PTHREAD ID   OSIPRI  OSSPRI  STATE
         _main_    0x8ec7128            0      0       0       OK
         errlog    0x8eca338   3076283312     10       0       OK
         taskwd    0x8ecf630   3076012976     10       0       OK
     timerQueue    0x8f0e630   3075611568     70       0       OK
          cbLow    0x8f0f4c8   3074816944     59       0       OK
       cbMedium    0x8f0e130   3073760176     64       0       OK
         cbHigh    0x8f0f848   3072703408     71       0       OK
       dbCaLink    0x8ecdeb8   3071646640     50       0       OK
       scanOnce    0x8f134a0   3070589872     70       0       OK
         scan10    0x8f139c8   3069533104     60       0       OK
          scan5    0x8f13be8   3068476336     61       0       OK
          scan2    0x8f13e08   3067419568     62       0       OK
          scan1    0x8f14028   3066362800     63       0       OK
        scan0.5    0x8f14248   3065306032     64       0       OK
        scan0.2    0x8f14468   3064249264     65       0       OK
        scan0.1    0x8f14688   3063192496     66       0       OK
      CAC-event    0x8f2fe38   3062397872     52       0       OK
        CAS-TCP    0x8f36b30   3061865392     16       0       OK
     CAS-beacon    0x8f36d60   3061463984     14       0       OK
        CAS-UDP    0x8eca0f8   3061062576     12       0       OK
      CAS-event    0x8f5a670   3056245680     18       0       OK
     CAS-client    0x8f6e0e8   3055188912     20       0       OK
Jeff
__________________________________________________________
Jeffrey O. Hill               Mail         [email protected]
LANL MS H820                  Voice        505 665 1831
Los Alamos NM 87545 USA       Fax          505 665 5107
Jeff
Ralph Lange               [email protected]     Tel: +49 30 6392-2117
BESSY Controls Group      www.bessy.de             Fax:      ...   -4859
RE: posix thread priorities Jeff Hill
Re: posix thread priorities Andrew Johnson
Prev: linux-x86_64 issue: epicsThread: Unknown C++ exception in thread "timerQueue" Ernest L. Williams Jr.
Next: Re: multiple error messages Benjamin Franksen
Index: 2002  2003  2004  <20052006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: posix thread priorities Jeff Hill
Next: RE: posix thread priorities Jeff Hill
