2002  2003  2004  <20052006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 2002  2003  2004  <20052006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: R3.14.8 Status/logClient patch
To: "Jeff Hill" <[email protected]>, [email protected]
Date: Fri, 18 Nov 2005 15:25:58 +0100
Jeff,
I discovered a problem. I wrongly claimed that I successfully tested a
soft ioc runnign on HP-UX. I must have missed something -- in fact it
doesn't even work in (unchanged) R3.14.7. The symptom is:
iocLogInit
log client: Unable to connect to "193.149.12.184:7004" because
0="Operation now in progress"
Note: the text in this message corresponds to errno=EINPROGRESS, whereas
the reported errno is 0.
I am stupefied as to how this is possible.
The code that gives this message is in logClientConnect(). It connects
and in case of a negatie return value, makes a copy of errno. Then it
checks the errno copy for various values and on SOCK_EISCONN decides
that we are connected.
A 'fix' that seems to work (on vxWorks-68040, linux-x86 and HP-UX) is to
check if errno is 0 (zero) (even if the return code is negative) and
assume a successful connect in this case. That is, treat errno==zero
the same as errno==EISCONN.
Any thoughts, comments, suggestions?
Cheers,
Ben
PS: I attached the latest version.
Attachment: newLogClient.tar.gz
Description: application/tgz
RE: R3.14.8 Status/logClient patch Jeff Hill
Prev: Re: multiple error messages Benjamin Franksen
Next: RE: posix thread priorities Jeff Hill
Index: 2002  2003  2004  <20052006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Re: linux-x86_64 issue: epicsThread: Unknown C++ exception in thread "timerQueue" Ernest L. Williams Jr.
Next: RE: R3.14.8 Status/logClient patch Jeff Hill
