2002  2003  2004  <20052006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 2002  2003  2004  <20052006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: R3.14.8 Status
To: EPICS core-talk <[email protected]>
Date: Tue, 22 Nov 2005 08:30:48 -0600
Andrew Johnson wrote:
Ok, we are aware of the following outstanding issues, none of which Marty or I regard as show-stoppers for the R3.14.8 release:
* USE_POSIX_THREAD_PRIORITY_SCHEDULING = YES on Linux 2.6.x
The test was on kernel 2.6.10-1.771_FC2
I ran libCom/test epicsThreadPriorityTestHost and epicsMessageQueueTestHost
when run as root they worked OK.
when not brun as root they just terminated immediately.
I found that when epicsThreadExitMain was called the process terminated instead of just the main thread.
I did not test with USE_POSIX_THREAD_PRIORITY_SCHEDULING = NO.
This looks like a bug in pthreads on linux not a bug in epics base. It should not stop the release.
Marty
Re: R3.14.8 Status Marty Kraimer
R3.14.8 Status Andrew Johnson
Prev: commit Jeff Hill
Next: Re: R3.14.8 Status Marty Kraimer
Index: 2002  2003  2004  <20052006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: R3.14.8 Status Andrew Johnson
