Hm.
the follow => 1 is needed, else makeBaseApp won't follow symbolic links.
(That's perl 5.8.4 on Linux).
Find used to work for symbolic links without the extra argument, but for
this perl it is needed. (I don't have all perl versions here, so I can't
tell when Find was changed to not follow symlinks by default.)
What does the perl doc on your cygwin system say on find() ?
Ralph
Janet Anderson wrote:
Ralph,
The following changes do not work on win32. On win32 no directories
and files are created and there are no error messages.
This is using cygwin perl v5.8.7.
Janet
Index: makeBaseApp.pl
RCS file:
/usr/local/epicsmgr/cvsroot/epics/base/src/makeBaseApp/makeBaseApp.pl,v
retrieving revision 1.32.2.5
retrieving revision 1.32.2.6
diff -r1.32.2.5 -r1.32.2.6
5c5
< # $Id: makeBaseApp.pl,v 1.32.2.5 2005/05/26 16:00:58 anj Exp $
> # $Id: makeBaseApp.pl,v 1.32.2.6 2005/09/21 15:02:53 lange Exp $
116c116
< find(\&FCopyTree, "$top/$f") unless (-e "$f");
> find({wanted => \&FCopyTree, follow => 1}, "$top/$f") unless (-e
"$f");
124c124
< find(\&FCopyTree, "$top/$apptypename");
> find({wanted => \&FCopyTree, follow => 1}, "$top/$apptypename");
133c133
< find(\&FCopyTree, "$top/$apptypename/ioc");
149c149
< find(\&FCopyTree, "$top/$apptypename/");
> find({wanted => \&FCopyTree, follow => 1}, "$top/$apptypename/");
-------- Original Message --------
Subject: RE: R3.14.8 makeBaseApp.pl
Date: Wed, 23 Nov 2005 15:42:59 -0700
To: 'Janet Anderson' <[email protected]>
CC: 'EPICS core-talk' <[email protected]>
> I just tried makeBaseApp.pl on win32 and it prompted me
> ok but it did not create any files or directories.
> Do you have the same problem?
I see that also. That's probably a recently introduced behavior.
Jeff
> -----Original Message-----
> From: Janet Anderson [mailto:[email protected]]
> Sent: Wednesday, November 23, 2005 12:20 PM
> To: Hill Jeff
> Subject: R3.14.8 makeBaseApp.pl
> Hi Jeff,
> Janet
Ralph Lange [email protected] Tel: +49 30 6392-2117
BESSY Controls Group www.bessy.de Fax: ... -4859
- Re: [Fwd: RE: R3.14.8 makeBaseApp.pl] Ralph Lange
- [Fwd: RE: R3.14.8 makeBaseApp.pl] Janet Anderson
<2005>
2025
2026
<2005>
2025
2026
