2002  2003  2004  <20052006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 2002  2003  2004  <20052006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: R3.14.8 makeBaseApp.pl - File::Find problem on cygwin
To: Ralph Lange <[email protected]>
Cc: [email protected]
Date: Tue, 29 Nov 2005 17:47:42 -0600
Ralph Lange wrote:
so - as makeBaseApp's use of find() follows exactly the third form mentioned in the synopsis - what you're saying is: On cygwin File::Find does not work as documented.
Janet looked at this, and discovered that the find() only works if we give it a starting path in the form d:\path\to\dir whereas makeBaseApp.pl was giving it /cygdrive/d/path/to/dir -- there's probably something inside cygwin that makes the /cygdrive/ path a link that isn't followed, or something equally wierd.
We've added another function LocalPath() which does the reverse conversion that UnixPath() does, and the resulting makeBaseApp.pl now works properly on Windows. However there's a parallel problem with the definition of TOP in the generated iocBoot/iocXxx/envPaths file when built on the Borland target (the borland stuff is more picky when it comes to paths), so I'm looking at installing a similar path mangling function into convertRelease.pl which we'll test tomorrow.
To quote a comment in makeBaseApp.pl: Bl**dy Windows stupidity...
- Andrew
* * Matt Santos / / Leo McGarry * * For a Brighter America * *
RE: [Fwd: RE: R3.14.8 makeBaseApp.pl] Jeff Hill
Re: R3.14.8 makeBaseApp.pl - File::Find problem on cygwin Ralph Lange
Prev: Re: main trunk build failure on win32 Andrew Johnson
Next: appDevGuide Marty Kraimer
Index: 2002  2003  2004  <20052006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Re: R3.14.8 makeBaseApp.pl - File::Find problem on cygwin Ralph Lange
Next: FW: ms and setvbuf Jeff Hill
