2002  2003  2004  <20052006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 2002  2003  2004  <20052006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: Revision numbers
Cc: EPICS Core-Talk <[email protected]>
Date: Fri, 16 Dec 2005 00:17:25 -0500
On Thu, 2005-12-15 at 17:59 -0600, Andrew Johnson wrote:
> Ernest L. Williams Jr. wrote:
> > There is already a patch listed in the "Known Problems" section for the
> > R3.14.8 release. Does the patch make it R3.14.8.1 or is there more?
> There are also some Win32 changes to do with exported symbols that are
> needed for Asyn.
> > Well, I think that a 4th revision number is okay to describe a patch.
> > What does each number represent in your current definition of the
> > Revision numbering scheme?
>  From the current configure/CONFIG_BASE_VERSION:
> EPICS_VERSION=3
> EPICS_REVISION=14
> EPICS_MODIFICATION=8
> EPICS_UPDATE_NAME=
> EPICS_UPDATE_LEVEL=0
> The variable names are not particularly meaningful, and the two UPDATE
> items may be about to be replaced with something else.
> EPICS_VERSION used to mean the version of the CA protocol; different
> versions were not expected to be able to talk to each other.
> EPICS_REVISION increases indicates a significant change in features
> and/or functionality, and may require significant effort to upgrade IOCS
> and/or support applications (3.13 to 3.14).  EPICS_MODIFICATION
> increments indicate minor enhancements to features and APIs, and
> incorporation of bug fixes.
> EPICS_UPDATE_NAME were originally designed for the words 'alpha'/'beta'
> and EPICS_UPDATE_LEVEL for the alpha/beta version number.  We'd like to
> replace these two with a new EPICS_PATCH_LEVEL variable, and add a
> variable EPICS_CVS_SNAPSHOT that distinguishes between official releases
> and CVS snapshots.  Between official releases, the version numbers would
> look like 3.14.8-CVS.
> We're also adding an EPICS_SITE_VERSION string in configure/CONFIG_SITE
> that allows sites to easily append their own version information to the
> EPICS version string - if set this will be appended after the -CVS.
> This is most of the new CONFIG_BASE_VERSION file:
> > EPICS_VERSION = 3
> > EPICS_REVISION = 14
> > # This part may contain letters, eg 0beta1
> > EPICS_MODIFICATION = 8
> > # Not included if zero
> > EPICS_PATCH_LEVEL = 0
> > # This must be -CVS or (during an official release) blank
> > EPICS_CVS_SNAPSHOT=-CVS
> > # No changes should be needed below here
> > ifneq ($(EPICS_PATCH_LEVEL),0)
> >   EPICS_PATCH_VSTRING=.$(EPICS_PATCH_LEVEL)
> > endif
> > ifneq ($(strip $(EPICS_SITE_VERSION)),)
> >   EPICS_SITE_VSTRING=-$(EPICS_SITE_VERSION)
> > endif
> > EPICS_SHORT_VERSION=$(EPICS_VERSION).$(EPICS_REVISION).$(EPICS_MODIFICATION)$(EPICS_PATCH_VSTRING)
> > EPICS_VERSION_NUMBER=$(EPICS_SHORT_VERSION)$(EPICS_CVS_SNAPSHOT)$(EPICS_SITE_VSTRING)
> > EPICS_VERSION_STRING="EPICS Version $(EPICS_VERSION_NUMBER)"
I really like this scheme.
> Ralph:
> Your local definitions for UPDATE_NAME and UPDATE_LEVEL would be
> combined into EPICS_SITE_VERSION in the CONFIG_SITE file.  Is the above
> likely to be sufficient for BESSY's needs?  Thanks for pointing out the
> additional uses of those var's BTW.
> Looking at the HPUX addition to SHRLIB_SEARCH_FULLPATHDIRS in the
> os/CONFIG_SITE.Common.hpux-parisc file, I think you could do this an
> easier way: If you add an entry to your base/configure/RELEASE file
> pointing to the /opt/... install location top, and ensure that there is
> actually a lib/hpux-parisc directory present before you build base, then
> that lib directory will get added to SHRLIB_SEARCH_DIRS inside base's
> auto-generated CONFIG_APP_INCLUDE file.  I'm not sure whether you'd need
> that RELEASE file entry just in base, or in your support modules too -
> that depends whether the definition of EPICS_BASE in the support modules
> points to the development location or to the /opt/... install directory.
>   Overall I suspect this would be a cleaner way to get your install
> directory into the runtime search path as it puts the site-specific path
> into the RELEASE file.
> I've just committed this change to CVS but haven't touched the hpux
> stuff, if you have time please have a look and work out how you want to
> play this.
> Thanks,
> - Andrew
Revision numbers Andrew Johnson
Re: Revision numbers Ernest L. Williams Jr.
Re: Revision numbers Andrew Johnson
Prev: Re: Revision numbers Andrew Johnson
Next: VDCT expand and template constructs Rees, NP (Nick)
Index: 2002  2003  2004  <20052006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Next: Re: Revision numbers Ralph Lange
