2002  2003  2004  <20052006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 2002  2003  2004  <20052006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: VDCT expand and template constructs
To: [email protected]
Date: Fri, 16 Dec 2005 19:20:23 +0100
On Friday 16 December 2005 18:51, Kay-Uwe Kasemir wrote:
> On Dec 16, 2005, at 12:05 , Rees, NP (Nick) wrote:
> > conflict between
> > macros used as text substitution macros and macros used as port
> > macros -
> > these are subtly different. If a port macro is not resolved then it
> > shouldn't be an error, I believe it should be treated as if it
> > never existed in
> > the first place. If a text substitution macro is not resolved then
> > it should remain as the macro to be substituted at a later time.
> Hi Nick:
> Not sure if I get this.
> Are 'port' macros always output connections,
> while 'text' macros are always inputs?
> Or is this beyond in/out direction?
I think you misunderstood the point. The way in which port macros have
an opposite direction compared to normal macros is in the way they are
resolved. To quote from the link Nick gave:
"Hierarchical templates as implemented by VisualDCT must allow macro
values to be passed into the template instance (giving values for
fields within the expanded template), and values to be exported from
the template instance to the higher level (usually the destination
field name for a link in a record defined in the higher level .vdb
file)."
Ben
VDCT expand and template constructs Rees, NP (Nick)
Re: VDCT expand and template constructs Kay-Uwe Kasemir
Prev: Re: VDCT expand and template constructs Kay-Uwe Kasemir
Next: Re: VDCT expand and template constructs Andrew Johnson
Index: 2002  2003  2004  <20052006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
