2002  2003  2004  2005  <2006>  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 2002  2003  2004  2005  <2006>  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: 3.14.8 / cygwin dependency
To: Janet Anderson <[email protected]>
Cc: EPICS Core Talk <[email protected]>
Date: Mon, 23 Jan 2006 15:47:19 +0100
Hi Janet,
I found the change that broke the non-cygwin build:
In RULES_BUILD 1.88.2.14 the line to install binaries was changed from
  @$(INSTALL_PRODUCT) -d -m 555 $< $(INSTALL_BIN)
to
  ifdef WIN32
      @$(INSTALL_PRODUCT) -d -m 555 $<* $(INSTALL_BIN)
  else
  endif
Immediately afterwards the wildcard was taken back for BORLAND compilations.
The problem is that the standard Windows shell - or whatever make uses to call programs on non-cygnus systems - does not allow wildcards in this place. Changing the "$<*" to "$(wildcard $<*)" lets make do the wildcard job, which should be the better option, anyway.
What exactly were you trying to "catch" with that wildcard? For my Microsoft non-cygnus system I actually can't think of any other files that would be matched by it.
I didn't commit any changes to CVS as I wasn't sure about the usefulness of that wildcard. So - if we need the wildcard, please change it as shown above, which will work everywhere. If we don't need the wildcard, going back to the traditional line is fine with me.
Cheers,
Ralph
3.14.8 / cygwin dependency Ralph Lange
Prev: Re: Revision numbers Andrew Johnson
Next: Re: 3.14.8 / cygwin dependency Ralph Lange
Index: 2002  2003  2004  2005  <2006>  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: 3.14.8 / cygwin dependency Ralph Lange
