On Tuesday 31 January 2006 21:42, Andrew Johnson wrote:
> The ?allocMustSucceed() routines were always a bit of a hack to avoid
> having to check the return value from ?alloc. They are only called
> in dbStaticLib and the IOC startup code in places where if you run
> out of memory there's no way you're going to be able to recover and
> still bring up the IOC, so the only thing you can do is bail out.
Dear Andrew
unfortunately, this is not true. The routines dbCalloc() and dbMalloc(),
defined in dbStaticLib to be more or less synonyms for
xxxMustSucceed(), are used all over the place. One instance I just
stumbled over is in dbAccess.c, where dbCalloc() is used in routine
dbPutFieldLink(). Here is a list:
aragon: .../3-14-8-2-0/src > pwd
/opt/Epics/R3.14.8/base/3-14-8-2-0/src
aragon: .../3-14-8-2-0/src > grep 'db[CM]alloc' **/*.c | grep -v Static
as/asDbLib.c: paddr = dbCalloc(1,sizeof(DBADDR) +
sizeof(ASCLIENTPVT));
db/dbAccess.c: pdbAddr = dbCalloc(1,sizeof(struct dbAddr));
db/dbCa.c:epicsShareFunc void * epicsShareAPI dbCalloc(size_t
nobj,size_t size);
db/dbCa.c: pca = (caLink*)dbCalloc(1,sizeof(caLink));
db/dbCa.c: pca->pvname = dbCalloc(1,strlen(pvname) +1);
db/dbCa.c: pca->pputString =
dbCalloc(MAX_STRING_SIZE,sizeof(char));
db/dbCa.c: pca->pputNative = dbCalloc(pca->nelements,
db/dbCa.c: pca->pgetNative =
dbCalloc(pca->nelements,element_size);
db/dbCa.c: pca->pgetString =
db/dbLock.c: plockSet = dbCalloc(1,sizeof(lockSet));
db/dbLock.c: plockRecord = dbCalloc(nrecords,sizeof(lockRecord));
db/dbLock.c: paplockRecord =
dbCalloc(nlockRecords,sizeof(lockRecord*));
db/dbNotify.c: pputNotifyPvt = dbCalloc(1,sizeof(putNotifyPvt));
db/dbNotify.c: pnotifyGlobal = dbCalloc(1,sizeof(notifyGlobal));
db/dbNotify.c: precord->ppnr =
dbCalloc(1,sizeof(putNotifyRecord));
db/dbNotify.c: pto->ppnr = dbCalloc(1,sizeof(putNotifyRecord));
db/dbNotify.c: pdbaddr = dbCalloc(1,sizeof(DBADDR) + len+1);
db/dbNotify.c: ppn = dbCalloc(1,sizeof(putNotify));
db/dbNotify.c: ptpnInfo = dbCalloc(1,sizeof(tpnInfo));
db/dbScan.c: pevent_scan_list =
dbCalloc(1,sizeof(event_scan_list));
db/dbScan.c:
*ppioscanpvt=dbCalloc(NUM_CALLBACK_PRIORITIES,sizeof(io_scan_list));
db/dbScan.c: papPeriodic = dbCalloc(nPeriodic,sizeof(scan_list*));
db/dbScan.c: periodicTaskId = dbCalloc(nPeriodic,sizeof(void *));
db/dbScan.c: psl = dbCalloc(1,sizeof(scan_list));
db/dbScan.c: pse = dbCalloc(1,sizeof(scan_element));
db/dbTest.c: papfields = dbCalloc(nfields,sizeof(char *));
misc/iocInit.c: pdbAddr = dbCalloc(1,sizeof(struct
dbAddr));
rec/compressRecord.c: pcompress->wptr = (double
*)dbCalloc(nelements,sizeof(double));
Many of these calls are /not/ restricted to happening only during
iocInit.
Ben
Re: enhanced seq record Brian McAllister
DBD Syntax (Arrays) Benjamin Franksen
<2006>
2025
2026
RE: Patches for ARM Linux target Jeff Hill
<2006>
2025
2026
