2002  2003  2004  2005  <20062007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 2002  2003  2004  2005  <20062007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: 3.15 C++ Exception classes
To: [email protected]
Date: Fri, 24 Feb 2006 10:40:40 +0100
On Friday 24 February 2006 00:35, Jeff Hill wrote:
> Subject 2) A severity returning function verses an augmented
> exception hierarchy.
> Of course the trade off here is more or less catch phrases in the
> exception handler.
> Case A:
> Catch ( warning & )
> Catch ( error & )
> Catch ( severe & )
> Case B:
> Catch ( Exception & e ) {
> 	Print e.what ()
> 	Print ( e.severity() )
> Now, admittedly, if Ben is right and we only need really to track two
> situations {unexpectedFault, externalConditionInfluencedFault} then
> there would need to be only two catch phrases. That can't be
> difficult.
Hi Jeff,
I think it is even easier: you normally /don't/ handle the
'unexpectedFault' exception. You let it crash. Ah, well, that needs to
be qualified:
What I mean is that such exceptions should not be handled in the
overwhelming majority of cases. There will be one place where it makes
sense to catch such an exception, namely in the supervisor/init thread
that has set up and started the component that failed unexpectedly.
Because this is the only place where we have all the necessary
information to restart such a component.
Code that only invokes services of a component (like CA) should only
handle the expected (external) conditions.
Ben
Prev: RE: 3.15 C++ Exception classes Jeff Hill
Next: XML is dead, long live ML9 Benjamin Franksen
Index: 2002  2003  2004  2005  <20062007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Fwd: Re: 3.15 C++ Exception classes Benjamin Franksen
