On Friday 24 February 2006 20:44, Kay-Uwe Kasemir wrote:
> You can't directly compare that to the exception::what()
> or event queue,
> because he's talking about an environment where
> each message (a new CA monitor, an error message, ...)
> is passed between processes which can't share anything.
Yes. OTOH, since Erlang is a functional language, all data is
'constant' (immutable) anyway, so sharing stuff between threads would
be possible, in principle. They don't do it, because they want GC to be
per-thread, not global, in order to reduce GC induced latency. (Note:
Erlang was not designed for hard real-time tasks; there /is/ GC latency
and it is not predictable in general. In practice, however, it is so
low, that you can neglect it for almost all applications.)
> So the database posting a monitor and channel access queuing it,
> or the exception thrower and the catcher,
> would all be different processes,
If EPICS was implemented in Erlang, /each record/ would get it's own
thread. (And CA would disappear because message passing in Erlang is
already network capable. Well, even records would probably disappear,
at least as regards data storage, since Erlang already comes with a
(replicable, distributed) run-time database. We would still need to
program record /processing/. Note, I mention all this only for
illustration, it is all theoretical, not a proposal in any way.)
> pointers wouldn't work between them.
> He also envisions some global garbage collector.
He isn't 'envisioning' anything. Erlang is GC'd language and has been
sucessfully used for production control systems with extreme
reliability and scalability requirements. (telephone switches with < 3
minutes/year downtime, etc..).
> I think java is somewhere in between:
> You can still share pointers between threads,
> but only pointers to objects, not types like 'double'.
> and you have garbage collection.
> That's already easier to use than C/C++,
> and you don't enter yet another string-related discussion
> with every API that anybody suggests for anything.
> But at the same time, java is already slower than C/C++,
> and I wonder about the performance of Erlang.
Much better than Java, I bet. Not as fast as C or C++. Particularly,
Erlang does /not/ specialize in number-crunching.
However, its built-in concurrency and distribution support is extremely
efficient and scalable. This can easily tip the balance for code that
is heavily multi-threaded and/or distributed. See for instance
http://www.sics.se/~joe/apachevsyaws.html. BTW, Erlang is reported to
have been benchmarked with 20 million (!) processes on a single machine
(the latest UltraSPARC with lots of memory, IIRC).
Of course, Erlang's runtime system is written in (fine-tuned,
hand-optimized) C...
Cheers,
Ben
- Re: Erlang Kay-Uwe Kasemir
- Re: Erlang Steve Lewis
- RE: XML is dead, long live ML9 Jeff Hill
- Re: XML is dead, long live ML9 Kay-Uwe Kasemir
More on the evils of referencing: Iterators verses Callbacks Jeff Hill
<2006>
2025
2026
<2006>
2025
2026
