Hi Matthias,
Matthias Clausen wrote:
in preparation for my meeting with Geoff at Fermilab I wand to send you
the proposed hook into base which Bernd Schoeneburg and Bob already
'somehow' agreed on:
Here's Berns mail to Bob:
recGblResetAlarms is called in monitor() which is called in the end of
record processing just before recGblFwdLink and after
recGblGetTimeStamp. After calling recGblResetAlarms in monitor() the
value changes are checked (not interesting for us). recGblResetAlarms
checks for alarm changes and returns the fist approach of the monitor
mask, which is later used for postEvents. postEvents can be called
from anywhere like device support, snl, subroutines, 'homebrew'
records etc. I think recGblResetAlarms is called in the monitor
function of records only. So I think it is the perfect place. Please
check it and correct me if I am wrong.
The code could look like this (the end of recGblResetAlarms):
if(sevr!=nsev || stat!=nsta) {
++: logAlarm (pdbc, sevr, stat);
++: /* nsev and nsta are in pdbc->sevr and pdbc->stat */
ackt = pdbc->ackt; acks = pdbc->acks;
if(!ackt || nsev>=acks){
pdbc->acks=nsev;
db_post_events(pdbc,&pdbc->acks,DBE_VALUE);
return(mask);
My question:
Do you also agree with approach?
I agree with the location and arguments of the call, which I believe are
the same as Fermilab have been using.
And - what would be implemented in base for logAlarm ()?
This could be an empty function which just returns - or it could be the
'real' thing where you'll have to check whether alarm logging should be
used at all.
The empty function could be replaced/ overloaded by the 'real' function
if you want to use putAlarm.
I think we just need a global pointer for the routine which will be
called if it's not NULL, so your code just sets it to hook in. Here's
my proposed patch:
Index: recGbl.h
RCS file: /net/phoebus/epicsmgr/cvsroot/epics/base/src/db/recGbl.h,v
retrieving revision 1.9
diff -u -b -r1.9 recGbl.h
--- recGbl.h 12 Feb 2003 21:22:23 -0000 1.9
+++ recGbl.h 19 Jun 2006 15:25:16 -0000
@@ -30,13 +30,23 @@
: FALSE\
+/* Structures needed for args */
-/* Global Record Support Routines*/
struct link;
struct dbAddr;
struct dbr_alDouble;
struct dbr_ctrlDouble;
struct dbr_grDouble;
+struct dbCommon;
+/* Hook Routine */
+typedef void (*RECGBL_ALARM_HOOK_ROUTINE)(struct dbCommon *prec,
+ unsigned short sevr, unsigned short stat);
+extern RECGBL_ALARM_HOOK_ROUTINE recGblAlarmHook;
+/* Global Record Support Routines */
epicsShareFunc void epicsShareAPI recGblDbaddrError(
long status, struct dbAddr *paddr, char *pcaller_name);
epicsShareFunc void epicsShareAPI recGblRecordError(
Index: recGbl.c
RCS file: /net/phoebus/epicsmgr/cvsroot/epics/base/src/db/recGbl.c,v
retrieving revision 1.60.2.2
diff -u -b -r1.60.2.2 recGbl.c
--- recGbl.c 4 Nov 2004 19:21:08 -0000 1.60.2.2
+++ recGbl.c 19 Jun 2006 15:25:16 -0000
@@ -42,6 +42,10 @@
#include "recGbl.h"
+/* Hook Routines */
+RECGBL_ALARM_HOOK_ROUTINE recGblAlarmHook = NULL;
/* local routines */
static void getMaxRangeValues();
@@ -239,6 +243,7 @@
if(stat_mask)
db_post_events(pdbc,&pdbc->stat,stat_mask);
+ if (recGblAlarmHook) (*recGblAlarmHook)(pdbc, sevr, stat);
pdbc->acks=nsev;
If there is general agreement between DESY and FNAL about this, I'll
commit the change which will then appear in R3-14-9.
- Andrew
Not everything that can be counted counts,
and not everything that counts can be counted.
-- Albert Einstein
- Re: alarm hook Matthias Clausen
Re: External source code repository Andrew Johnson
RE: alarm hook Liyu, Andrei
<2006>
2025
2026
RE: External source code repository Liyu, Andrei
<2006>
2025
2026
