2002  2003  2004  2005  <20062007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 2002  2003  2004  2005  <20062007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: alarm hook
To: "Liyu, Andrei" <[email protected]>
Cc: Matthias Clausen <[email protected]>, Geoff Savage <[email protected]>, EPICS core-talk <[email protected]>, "Zhukov, Alexander P." <[email protected]>
Date: Mon, 19 Jun 2006 17:58:51 -0500
Hi Andrei,
You will be able to reimplement your logging code using the hook I am proposing. The routine called via the the recGblAlarmHook pointer is passed the *previous* values for the record's alarm status and severity as parameters, and can get the new values directly from the record's prec->stat and prec->sevr fields. Thus all the same information is available to the hook routine as was available where you inserted the changes in your modified version.
The aim of providing hooks like this is so that those sites that are not interested in functionality such as logging alarms are not significantly penalized, but users like you who want to do so are able to hook the IOC into their logging subsystem without having to make any changes to the source code of Base at all.
- Andrew
Not everything that can be counted counts,
and not everything that counts can be counted.
  -- Albert Einstein
RE: alarm hook Liyu, Andrei
Prev: RE: alarm hook Liyu, Andrei
Next: Re: alarm hook Matthias Clausen
Index: 2002  2003  2004  2005  <20062007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Next: RE: alarm hook Liyu, Andrei
