Hi Michael,
Laznovsky, Michael wrote:
Hi Andrew- were you the one asking about mutex's after my talk last
week? Sorry if my answer was a little incoherent... I'm sometimes not
at my best onstage.
Yes, that was me.
I can see a need for some kind of lock mechanism for array modification,
but would scalars really need it? I guess we could maybe have an option
to only modify variables at state transitions, if that sounds useful.
Some of the architectures that EPICS runs on do not have hardware
floating point, thus the updating of a double precision (64 bit)
floating point value can be interrupted half-way through. You wouldn't
want anybody reading that floating point value in the middle of
changing, so the only safe way to access it from another thread is by
protecting the storage with a mutex (or otherwise guaranteeing that
context switches are not occurring). Strings are another type that
objiously suffer from this problem.
Note that the above isn't the only place and reason you need to protect
the local variables, but its one scenario that demonstrates the issue
and which is relatively easy to understand. Unfortunately if you don't
do this right you may never see the problems it causes yourself, as they
may only show up on certain architectures, e.g. SMP systems.
To be truly portable, if a location is written to from a different
thread than the thread reading from it, there must be a mutex release
after the write instruction and a take before the read.
- Andrew
Not everything that can be counted counts,
and not everything that counts can be counted.
-- Albert Einstein
- RE: seq debugger Laznovsky, Michael
Re: RE: alarm hook Andrew Johnson
<2006>
2025
2026
RE: alarm hook Liyu, Andrei
<2006>
2025
2026
ANJ, 02 Feb 2012 |
Home
News
About
Talk
Base
Modules
Extensions
Distributions
Download
Documents
Links
Licensing
