Andrew,
Yes, you are right. This way should work too.
I worry it can be heavy (open some thousands CA channels, memory for
each channel and CPU time for universal CA algorithm). Maybe
sendToNetwork (separate thread) would lose possible generic.
Thanks, Andrei.
-----Original Message-----
Sent: Friday, June 23, 2006 5:57 PM
To: Liyu, Andrei
Cc: Dalesio, Leo `Bob`; Matthias Clausen; Geoff Savage; EPICS core-talk;
Fritz Bartlett; Bernd Schoeneburg
Subject: Re: alarm hook
Hi Andrei,
Liyu, Andrei wrote:
> Could you, please, explain better about local CA client?
> How can it subscribe to local records automatically? Or will it have
> list?
It can use the dbStaticLib routines to find out all of the record
instances that are loaded on the IOC, and set a CA monitor on each one -
see the example code at the end of the Static Database Access chapter of
the IOC Application Developers Guide for a starting point on doing the
dbStaticLib part.
> How standard CA client will send to log server? Or it is special CA
> application?
It is a CA client application that is run on each IOC, which knows how
to send alarm details to the log server.
- Andrew
Not everything that can be counted counts,
and not everything that counts can be counted.
-- Albert Einstein
Re: alarm hook Andrew Johnson
RE: alarm hook Liyu, Andrei
<2006>
2025
2026
<2006>
2025
2026
