Hi Andrew,
The patch below works fine.
Ernest
On Tue, 2006-12-05 at 13:26 -0600, Andrew Johnson wrote:
> Ernest L. Williams Jr. wrote:
> > This is a 6.x thing. All releases 6.0 thru 6.3 have the following:
> > $(WIND_BASE)/gnu/<gnu-version>-vxworks-<version>/x86-linux2
> Ok, this change in configure/os should fix it. It's a bit ugly, but
> setting WIND_HOST_TYPE to the correct value in the first place isn't
> really possible.
> Index: CONFIG.Common.vxWorksCommon
> RCS file:
> /net/phoebus/epicsmgr/cvsroot/epics/base/configure/os/CONFIG.Common.vxWorksCommon,v
> retrieving revision 1.35.2.10
> diff -u -b -r1.35.2.10 CONFIG.Common.vxWorksCommon
> --- CONFIG.Common.vxWorksCommon 2 Dec 2006 00:09:16 -0000 1.35.2.10
> +++ CONFIG.Common.vxWorksCommon 5 Dec 2006 19:19:05 -0000
> @@ -89,6 +89,14 @@
> VX_GNU_VERSION = $(VX_GNU_VERSION_$(VXWORKS_VERSION))
> +# Fix WIND_BASE for vxWorks 6.x on linux
> +ifeq ($(VXWORKS_MAJOR_VERSION),6)
> + ifeq ($(WIND_HOST_TYPE),x86-linux)
> + WIND_HOST_TYPE = x86-linux2
> + endif
> +endif
> # vxWorks directory definitions
> VX_DIR_5 = $(WIND_BASE)
> VX_DIR_6 = $(WIND_BASE)/vxWorks-$(VXWORKS_VERSION)
> I'm about to look at your other changes too.
> Thanks,
> - Andrew
- vxWorks 6.3 and EPICS R3.14.9-pre1 Ernest L. Williams Jr.
- Re: vxWorks 6.3 and EPICS R3.14.9-pre1 Andrew Johnson
- Re: vxWorks 6.3 and EPICS R3.14.9-pre1 Ernest L. Williams Jr.
RE: osiWireFormat.h problems Jeff Hill
<2006>
2025
2026
thread private exit hook added to EPICS base for R3.14.9 Jeff Hill
<2006>
2025
2026
