2002  2003  2004  2005  <2006>  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 2002  2003  2004  2005  <2006>  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: RE: Ca portable server Enum strin table
To: "'Gasper Jansa'" <[email protected]>
Cc: "'EPICS Core Talk'" <[email protected]>
Date: Thu, 7 Dec 2006 13:36:22 -0700
Hello Gasper,
I was looking through my mail stack and I think that I forgot to answer this
question.
> I was looking why enum string table is demanded by server library only
> the first time from gateway.
> I noticed in casPVI.cc that if string table already exists it is not
> requested by server tool anymore.
> So I commented out this lines in casPVI.cc in updateEnumStringTable()
> and updateEnumStringTableAsyncCompletion()
>    if ( this->enumStrTbl.numberOfStrings () > 0 ) {
>         return S_cas_success;
> Is there a reason why this is done?
> I commented this out since in other case I don't get updated string
> values to the clients if there is one monitor connected to the PV.
This could be a legitimate problem. Presumably you noticed this when someone
wrote to the fields containing the state labels in a mmbi or mbbo record? I
created entry 278 in the mantis bug tracker. I also committed a fix to CVS
(removing the code that you are commenting out). The fix will show up in
R3.14.9.
Thanks for reporting the bug, and Best Regards,
Jeff
> -----Original Message-----
> From: Gasper Jansa [mailto:[email protected]]
> Sent: Monday, November 27, 2006 11:32 AM
> To: Jeff Hill
> Subject: Ca portable server Enum strin table
> Dear Jeff
> Thank you for you previous answer.
> I have yet another question.
> Thank you in advance  and  Best regards,
> Gasper Jansa
Prev: RE: thread private exit hook added to EPICS base for R3.14.9 Jeff Hill
Next: Re: C strict aliasing rules Till Straumann
Index: 2002  2003  2004  2005  <2006>  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Next: configure/os/linux, configure/os/freebsd, configure/os/win32 .... Jeff Hill
