2002  2003  2004  2005  <20062007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 2002  2003  2004  2005  <20062007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: Sat. CVS snap built against vxWorks 6.3
Cc: EPICS Core Talk <[email protected]>
Date: Mon, 11 Dec 2006 14:21:42 -0500
On Mon, 2006-12-11 at 13:04 -0600, Andrew Johnson wrote:
> Hi Ernest,
> Ernest L. Williams Jr. wrote:
> > I ran into a build issue with vxWorks 6.3 regarding WIND_HOST_TYPE.
> > The patch you provided works provided there is no definition
> > WIND_HOST_TYPE in "CONFIG.<EPICS_HOST_ARCH>.Common"
> > Specifically, I had to remove the WIND_HOST_TYPE definition in
> > CONFIG.linux-x86.Common  and CONFIG.linux-x86_64.Common
> By removing the setting from those files you are just using the value of
> your WIND_HOST_TYPE environment variable.  If you unset that, it'll stop
> working again, which is not a desirable outcome.
You are right due to my vxWorks install; I have WIND_HOST_TYPE set
in .bash_profile along with WIND_BASE, etc...
> The problem is that make doesn't know the value of $(VXWORKS_VERSION) at
> the point where I'm using it.  I can solve one use easily, but I'm going
> to have to talk to Janet about the other.  Luckily I think I can debug
> it fairly easily without having vxWorks 6 installed, since it appears in
> the compiler path that is the first thing actually run in a vxWorks 6 build.
The same happens when I try to build for vxWorks 5.5.1.
> Once this issue is resolved, I'll be tagging R3-14-9-pre2 (we're only
> just over a week late).
> - Andrew
Re: Sat. CVS snap built against vxWorks 6.3 Andrew Johnson
Sat. CVS snap built against vxWorks 6.3 Ernest L. Williams Jr.
Prev: Re: Sat. CVS snap built against vxWorks 6.3 Andrew Johnson
Next: Re: Sat. CVS snap built against vxWorks 6.3 Andrew Johnson
Index: 2002  2003  2004  2005  <20062007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
