2002  2003  2004  2005  <20062007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 2002  2003  2004  2005  <20062007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: C++ Exceptions from CAC-UDP on exit
To: Jeff Hill <[email protected]>
Cc: "'EPICS core-talk'" <[email protected]>
Date: Thu, 14 Dec 2006 14:18:24 -0600
Jeff Hill wrote:
The root problem here I suspect is that DB CA link code does not have a
shutdown procedure and therefore it is not destroying its CA context before
the process exits. So when the process rundown starts and the resources that
the UDP thread uses start to cease to exist then the UDP thread crashes.
If that is the problem the I agree we don't have much chance of fixing it. The strange thing though is that it's reporting an unknown C++ exception, so there is probably still something there that's able to catch whatever it being thrown. If we could modify the CAC-UDP task to expect that exception we could at least suppress the warning message, or convert it to something a little more innocuous.
What OS do you see this on? We might be able to attach with a debugger to
get more detail, but I suspect that we will only see that the above
suspicions are accurate.
I've only seen it on linux-x86 so far - I tried it on Solaris but it didn't occur there, and I've not run the tests on vxWorks yet.
- Andrew
There is considerable overlap between the intelligence of the smartest
bears and the dumbest tourists -- Yosemite National Park Ranger
RE: C++ Exceptions from CAC-UDP on exit Jeff Hill
Prev: RE: C++ Exceptions from CAC-UDP on exit Jeff Hill
Next: RE: C++ Exceptions from CAC-UDP on exit Jeff Hill
Index: 2002  2003  2004  2005  <20062007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
