2002  2003  2004  2005  <20062007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 2002  2003  2004  2005  <20062007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: [solved:] no bug in build system (though questions remain)
To: [email protected]
Date: Thu, 14 Dec 2006 22:10:49 +0100
On Thursday 14 December 2006 16:33, Janet Anderson wrote:
> I don't see the build problem.  The file
> exampleApp/src/sncProgram.st is not part
> of  the product example, it is part of  the host product sncProgram.
> The file sncExample.stt is part of the product example and when I
> define SNCSEQ in the RELEASE file, build the ioc application, and
> then touch src/sncExample.stt and do a make the example (from
> PROD_IOC_vxWorks = example)
> is rebuilt.
Sorry, my fault: I tried to quick, quick reproduce my problem with the
exampleApp, saw what I wanted to see and of course got it completely
wrong. The original problem I had is this: a library is built by
another application under the same top directory and the product that
uses the library isn't rebuilt when the library changes.. But now when
I try to reproduce my problem with the example app everything works
there.... [hours later] ok, found the error, all my own fault: the line
	xxx_LIBS += yyy
was included from a makefile snippet that was generated. I made the
error of including it at the end of the Makefile, i.e. /after/ including
configure/RULES. Putting the include /before/ the RULES fixes
everything. Ugh.
Anyway, there is one thing I'd like to remark on:
> Libraries outside the ioc application  will not be dependancies. The
> ioc application RELEASE file contains the following lines:
> # NOTE: The build does not check dependencies against files
> # that are outside this application, thus you should run
> # "gnumake distclean install" in the top directory each time
> # EPICS_BASE, SNCSEQ, or any other external module defined
> # in the RELEASE file is rebuilt.
I was aware of this. However, I dislike it pretty much, and I would like
to ask what its rationale is.
The reason I dislike it is that "make distclean install" can take quite
a long time for some of our applications. It is a pain to
rebuild /everything/ just because I made a small fix in one of out
drivers or device supports which would only require re-linking of some
of the final executables. (I am in the middle of converting all our
stuff from 3.13 to 3.14, including all our support modules, and this
requires fixing things, recompilation, testing, on and on and on.)
Obviously the restriction is not there because it is hard to implement.
Indeed, dependencies to all internal /and/ external libraries are
already contained in the generated MakefileInclude. This can be seen if
one dumps the value of the variable example_DEPLIBS (a list of the path
names of /all/ libraries linked into the product); and then there is
the line (also in MakefileInclude):
example$(EXE): $(example_OBJSNAME) $(example_RESS) $(example_DEPLIBS)
It even works (despite the disclaimer ;-) as I just tested:
ben@sarun: .../play/ioc-test > make -s
touch /opt/epics/R3.14.8/base/lib/linux-x86/libCom.a*
Installing library ../../../lib/linux-x86/libxxxSupport.a
Installing shared library ../../../lib/linux-x86/libxxxSupport.so
Installing binary ../../../bin/linux-x86/example
(Of course, I would need the same for header files, dbd and all else.)
Cheers
Ben
To the functional programmer's eye a loop is just a degenerate
form of linear recursion written in an adhoc special syntax.
Re: [solved:] no bug in build system (though questions remain) Andrew Johnson
Bug in generated MakefileInclude? Benjamin Franksen
Re: Bug in generated MakefileInclude? Janet Anderson
Prev: RE: C++ Exceptions from CAC-UDP on exit Jeff Hill
Next: Re: [solved:] no bug in build system (though questions remain) Andrew Johnson
Index: 2002  2003  2004  2005  <20062007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Re: Bug in generated MakefileInclude? Janet Anderson
