2002  2003  2004  2005  <20062007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 2002  2003  2004  2005  <20062007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: EPICS on Tru64unix and HP-UX
To: "Jeff Hill" <[email protected]>
Cc: [email protected], "'Andrew Johnson'" <[email protected]>, [email protected], "'EPICS core-talk'" <[email protected]>
Date: Fri, 22 Dec 2006 08:02:51 +0900
Hello Jeff,
Thank you very much for your investigation and the patch.  I'll try
it this evening as well as the improvement to CONFIG files.
I wish you all happy holidays.
Cheers.
>>> On Thu, 21 Dec 2006 15:34:09 JST,  "Jeff Hill" <[email protected]> wrote;
> Hello Kazuro,
> Sorry about the delay responding. Part of the reason was a closure of the
> lab here yesterday due to some significant snowfall here.
> > > Ok, I'm still waiting for a comment from Jeff Hill on your patch and/or
> > > the above compile error - we committed all of your other changes, but
> > > this is Jeff's code so he gets to decide what to do about it.
> The function overload supplied in the comBuf.h patch "bool push ( const char
> * value )" satisfies the compiler's quest for a function with the signature
> "bool push ( const char value [MAX_STRING_SIZE] )" but isn't 100% correct
> because the implementation pushes the value of a pointer into the stream
> instead of pushing a string of length MAX_STRING_SIZE into the stream.
> I had a look at why this compiler appears to not be using "template < class
> T > bool push ( const T & value )" for T set to epicsOldString. I think I
> see the cause in osdWireFormat.h. I committed a fix to CVS. Please try the
> latest version from the R3.14 branch in CVS when you get a chance in order
> to confirm if my suspicions are correct.
> Many thanks for your assistance with R3.14.9.
> PS: I have attached the patch for your review.
> PPS: I suspect that this matter is related to an issue detected by gcc 4.0
> several weeks ago - which apparently wasn't 100% fixed.
Kazuro FURUKAWA <[email protected]>
 Linac&KEKB,  High Energy Accelerator Research Organization (KEK), Japan
 Telephone: +81-29-864-5200 x4316,  Facsimile: +81-29-864-0321
RE: EPICS on Tru64unix and HP-UX Jeff Hill
Prev: RE: EPICS on Tru64unix and HP-UX Jeff Hill
Next: Re: EPICS on Tru64unix and HP-UX Kazuro FURUKAWA
Index: 2002  2003  2004  2005  <20062007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
