2002  2003  2004  2005  <20062007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 2002  2003  2004  2005  <20062007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: RE: EPICS on Tru64unix and HP-UX
To: <[email protected]>
Cc: "'Andrew Johnson'" <[email protected]>, <[email protected]>, "'EPICS core-talk'" <[email protected]>
Date: Fri, 22 Dec 2006 15:08:44 -0700
Kazuro,
I just noticed a few minutes ago a compile time error when building with g++
Linux. I committed a fix for this problem which may resolve your troubles
also.
Jeff
> -----Original Message-----
> From: [email protected] [mailto:[email protected]]
> Sent: Friday, December 22, 2006 1:52 PM
> To: Jeff Hill
> Cc: [email protected]; 'Andrew Johnson'; [email protected];
> 'EPICS core-talk'
> Subject: Re: EPICS on Tru64unix and HP-UX
> Hello Jeff,
> Sorry for my late reply.  I've got
>   <http://www.aps.anl.gov/epics/download/base/base_R3-14_cvs.tar.gz>
> dated Dec.22 06:07 GMT which include your patch, which gives
> errors in comQueSend.cpp as the following log.  And again with my
> dirty patch against comBuf.h it compiles keeping your change to
> osdWireFormat.h.  Sorry for my delay.
> cxx  -c   -pthread -ieee         -DUNIX  -D_OSF_SOURCE   -std gnu  -O
> -I. -I.. -I../../../include/os/osf -
> I../../../include         ../comQueSend.cpp
> cxx: Error: ../../../include/osiWireFormat.h, line 211: Cannot create
>           variable "tmp" of incomplete type "WireAlias<const char *>".
>           detected during:
>             instantiation of "void WireSet(const T &, epicsUInt8 *) [with
>                       T=const char *]" at line 191 of "../comBuf.h"
>             instantiation of
>                       "bool comBuf::push(const T &) [with T=const char *]"
> at
>                       line 144 of "../comQueSend.h"
>             instantiation of
>                       "void comQueSend::push(const T &) [with T=const char
>                       at line 112 of "../comQueSend.cpp"
>     WireAlias < T > tmp;
>           variable "tmp" of incomplete type "WireAlias<<error-type>>".
>           detected during:
>                       T=<error-type>]" at line 213
>             instantiation of
> at
>             instantiation of
> cxx: Warning: ../comQueSend.cpp, line 327: pointless comparison of
> unsigned
>           integer with zero
>     if ( INVALID_DB_REQ ( dataType ) ) {
> cxx: Info: 2 errors detected in the compilation of "../comQueSend.cpp".
> >>> On Thu, 21 Dec 2006 15:34:09 JST,  "Jeff Hill" <[email protected]>
wrote;
> > Hello Kazuro,
> > Sorry about the delay responding. Part of the reason was a closure of
> the
> > lab here yesterday due to some significant snowfall here.
> > > > Ok, I'm still waiting for a comment from Jeff Hill on your patch
> and/or
> > > > the above compile error - we committed all of your other changes,
> but
> > > > this is Jeff's code so he gets to decide what to do about it.
> > The function overload supplied in the comBuf.h patch "bool push ( const
> char
> > * value )" satisfies the compiler's quest for a function with the
> signature
> > "bool push ( const char value [MAX_STRING_SIZE] )" but isn't 100%
> correct
> > because the implementation pushes the value of a pointer into the stream
> > instead of pushing a string of length MAX_STRING_SIZE into the stream.
> > I had a look at why this compiler appears to not be using "template <
> class
> > T > bool push ( const T & value )" for T set to epicsOldString. I think
> I
> > see the cause in osdWireFormat.h. I committed a fix to CVS. Please try
> the
> > latest version from the R3.14 branch in CVS when you get a chance in
> order
> > to confirm if my suspicions are correct.
> > Many thanks for your assistance with R3.14.9.
> > PS: I have attached the patch for your review.
> > PPS: I suspect that this matter is related to an issue detected by gcc
> 4.0
> > several weeks ago - which apparently wasn't 100% fixed.
> > Best Regards,
> > Jeff
> > cvs diff -r R3-14-2_branch:yesterday -r R3-14-2_branch -u -wb -i (in
> > directory
> > D:\users\hill\epicsMainTrunk\epics\base\src\libCom\osi\os\default\)
> > cvs diff: Diffing .
> > Index: osdWireFormat.h
> > RCS file:
> /net/phoebus/epicsmgr/cvsroot/epics/base/src/libCom/osi/os/default/osdWire
> Fo
> > rmat.h,v
> > retrieving revision 1.1.2.3
> > retrieving revision 1.1.2.4
> > diff -c -u -w -b -i -r1.1.2.3 -r1.1.2.4
> > cvs diff: conflicting specifications of output style
> > --- osdWireFormat.h	5 Dec 2006 01:22:04 -0000	1.1.2.3
> > +++ osdWireFormat.h	21 Dec 2006 22:13:12 -0000	1.1.2.4
> > @@ -118,10 +118,11 @@
> >      dst = tmp._f;
> > -inline void WireGet (
> > +template <>
> > +inline void WireGet < epicsOldString > (
> >      const epicsUInt8 * pWireSrc, epicsOldString & dst )
> > -    memcpy ( & dst, pWireSrc, sizeof ( dst ) );
> > +    memcpy ( dst, pWireSrc, sizeof ( dst ) );
> >  template <>
> > @@ -147,10 +148,11 @@
> >  #   endif
> > -inline void WireSet (
> > +template <>
> > +inline void WireSet < const epicsOldString > (
> >      const epicsOldString & src, epicsUInt8 * pWireDst )
> > -    memcpy ( pWireDst, & src, sizeof ( src ) );
> > +    memcpy ( pWireDst, src, sizeof ( src ) );
> >  template <>
> > ***** CVS exited normally with code 1 *****
> > > Sent: Wednesday, December 20, 2006 3:54 PM
> > > To: Andrew Johnson
> > > Cc: Kazuro FURUKAWA; [email protected]; EPICS core-talk; Jeff
> Hill
> > > Hello Andrew,
> > > Thank you for detailed investigation.
> > > >>> On Wed, 20 Dec 2006 16:05:53 JST,  Andrew Johnson
> <[email protected]>
> > > wrote;
> > > > Hi Kazuro,
> > > > Kazuro FURUKAWA wrote:
> > > > > For Tru64unix...
> > > > > [1] comBuf.h
> > > > > I've tried it again without comBuf.h modification.  And I've got
> > > > > the following error.  I've changed the compiler features like
> > > > > -std {gun,ansi,ms,arm} and they gave me the same results.  I don't
> > > > > know why the error occurs, and why my change cures the
compilation.
> > > > > cxx  -c           -D_OSF_SOURCE -DUNIX   -std gnu -pthread -ieee
> -O
> create
> > > > >           detected during:
> > > [with
> "../comBuf.h"
> > > > >             instantiation of
> char
> > > *]" at
> > > > >             instantiation of
> T=const
> > > char *]"
> > > unsigned
> > > > >           integer with zero
> > > > > cxx: Info: 1 error detected in the compilation of
> > > > > I've put the full compilation log with above error at
> > > > > <URL:http://www-linac.kek.jp/jk/osf/base-3.14.9pr2-make-osf-
> > > failed.log>
> and/or
> but
> > > I understand.  The patch I added is nasty... There should be better
> > > approach.
> > > > > [2] snprintf()
> > > > > It seems the definition of the return value is different on Tru64.
> > > > > It simply returns the length of the buffer.  The buffer contents
> > > > > are OK.  The part of the results is like this.
> > > > > not ok  1 - epicsSnprintf(size=1) = 0
> > > > > ok  2 - buffer = ''
> > > > > ok  3 - length = 0
> > > > > not ok  4 - epicsSnprintf(size=2) = 1
> > > > > ok  5 - buffer = 'i'
> > > > > ok  6 - length = 1
> > > > > The return value should be 46.  We may include a version of free
> > > > > snprintf() into the source tree, but...
> > > > According to the C99 standard the return value from snprintf() is
> > > > supposed to be the number of characters that would have been written
> to
> > > > the buffer if it were large enough.  We're used to different
> operating
> > > > systems having different semantics for snprintf(), which is why we
> make
> > > > it possible for each architecture to implement their own workaround.
> > > > I'm not aware of any code in Base that will fail with the above
> issue,
> > > > but it would be good to fix this sometime - I won't hold up the
> R3.14.9
> > > > release waiting for it though.
> > > The document on Tru64unix says the current behavior.  Thus, it is a
> > > feature, not a bug.  They may have misunderstood the standard, or
> > > have followed a draft standard.
> > > I'm thinking about a dirty wrapper around their vsnprintf(), if I
> > > have time.
> > > > > [3] timer
> > > > > An example of the errore is like this.
> > > > > ./epicsTimerTest
> > > > > 1..33
> > > > > # Testing timer accuracy
> > > > > not ok  1 - percentError < messageThresh
> > > > > # delay = 1.000000 s, error = -0.007792 s (0.8 %)
> > > > > not ok  2 - percentError < messageThresh
> > > > > # delay = 1.100000 s, error = -0.007204 s (0.7 %)
> > > > > not ok  3 - percentError < messageThresh
> > > > > # delay = 1.200000 s, error = -0.007592 s (0.6 %)
> > > > > not ok  4 - percentError < messageThresh
> > > > > # delay = 1.300000 s, error = -0.007981 s (0.6 %)
> > > > > not ok  5 - percentError < messageThresh
> > > > > # delay = 1.400000 s, error = -0.007393 s (0.5 %)
> > > > > not ok  6 - percentError < messageThresh
> > > > > # delay = 1.500000 s, error = -0.007781 s (0.5 %)
> > > > > not ok  7 - percentError < messageThresh
> > > > > # delay = 1.600000 s, error = -0.008170 s (0.5 %)
> > > > > ok  8 - percentError < messageThresh
> > > > > Without load, software with usleep() or setitimer() normally shows
> > > > > 0-2 millisecond accuracy.  So the above discrepancies are large
> > > > > compared with my experiences.  We have 7 alpha machines at KEKB
> > > > > and Linac.  The numbers of processes are 200 to 600, and the load
> > > > > averages are 1 to 15.  The results do not change much between
> > > > > machines.  I don't know the origin of the errors.
> > > > I regard the earlier timer tests not so much as an error as a
> warning,
> > > > and since your machines are running signficant numbers of processes
> I
> > > > would not be too worried by the above failures.
> > > [4] LDLIBS
> > > I realized another inconsistency, as I tried R3.14-CVS dated
> > > Dec.20 for native compiler (namely osf-alpha, instead of osf-alpha-
> gnu).
> > > I should have used the flag -pthread instead of "-D_REENTRANT
> > > -lpthread ..." consistently for cc and ld.
> > > The rule is correctly followed for STRICT targets but not for
> > > others.
> > > Also as a side effect(?) -lm is not used in OP_SYS_LDLIBS for some
> > > targets.  epicsCalcTest for example fails to build with CVS-source.
> > > I had put "USR_SYS_LIBS += m" in CONFIG.Common.osf-alpha as a
> > > work-around in my patch, but maybe that is not clean.  I may look
> > > in more although I don't yet understand when OP_SYS_LDLIBS is
> > > overwritten.
> > > Cheers.
> > > Kazuro FURUKAWA <[email protected]>
> > >  Linac&KEKB,  High Energy Accelerator Research Organization (KEK),
> Japan
> > >  Telephone: +81-29-864-5200 x4316,  Facsimile: +81-29-864-0321
> よろしくお願いします。
> 古川 和朗,  Kazuro FURUKAWA <[email protected]>
>  Linac&KEKB,  High Energy Accelerator Research Organization (KEK), Japan
Re: EPICS on Tru64unix and HP-UX Kazuro FURUKAWA
Prev: Re: EPICS on Tru64unix and HP-UX Kazuro FURUKAWA
Next: RE: Status Report Jeff Hill
Index: 2002  2003  2004  2005  <20062007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Next: Re: EPICS on Tru64unix and HP-UX Kazuro FURUKAWA
