Ralph Lange wrote:
just found out (compiling streamDevice that includes a device support
for the calcout) that the generated header file calcoutRecord.h uses
definitions from postfix.h, but does not include it.
I know this is not illegal, but it's not very nice, too.
The postfix.h requirement is new in R3.14.9 - I did document it in the
release notes, but I agree that it's not very nice.
As calcoutRecord.h gets generated from dbd - is there an easy way to add
the #include directive or should we live with calcoutRecord.h being not
nice?
There was supposed to be -- I added support ("Cdefs") for this kind of
thing to dbStaticLib before R3.14.0alpha1 came out, but we've never used
it in anger and unfortunately it doesn't work for this particular case.
I suspect VDCT doesn't understand the Cdefs syntax either, so it may
barf when it sees a Cdefs line. This is the DBD syntax:
Index: calcoutRecord.dbd
RCS file:
/net/phoebus/epicsmgr/cvsroot/epics/base/src/rec/calcoutRecord.dbd,v
retrieving revision 1.5.2.2
diff -u -b -r1.5.2.2 calcoutRecord.dbd
--- calcoutRecord.dbd 3 Oct 2006 20:22:23 -0000 1.5.2.2
+++ calcoutRecord.dbd 12 Mar 2007 15:17:07 -0000
@@ -30,6 +30,7 @@
choice(calcoutINAV_CON,"Constant")
recordtype(calcout) {
+ %#include "postfix.h"
include "dbCommon.dbd"
field(VERS,DBF_DOUBLE) {
prompt("Code Version")
Any valid C code can follow a % sign (which must be inside a recordtype
definition) and will be added to the generated *Record.h file.
Unfortunately though the above "#include" statement gets added to the
calcoutRecord.h file *below* the struct calcoutRecord definition, which
is too late for postfix.h. I can fix that, but obviously not until the
next release.
In fact looking at it, I can clean up the dbStaticLib code slightly
using this technique - I can move all of the #include statements that
get put into the Record.h files from the dbToRecordTypeH.c program into
dbCommon.dbd, so this makes sense for the next release (but for now all
calcout device support will have to do the #include "postfix.h" itself).
The original idea for Cdefs was to allow each recordtype to define its
own DSET structure for the device supports to use, rather than each
support defining its own. I eventually concluded though that we're too
far gone to try and fix that particular design issue until we re-do the
whole devSup interface.
- Andrew
The right to be heard does not automatically include
the right to be taken seriously. -- Hubert H. Humphrey
- calcoutRecord.h Ralph Lange
Re: EPICS_TIMEZONE, TIMEZONE, vxWorks daylight saving Andrew Johnson
<2007>
2025
2026
<2007>
2025
2026
