Ernest L. Williams Jr. wrote:
In the case of an ioc application, the application source code does not
change between a vxWorks 5.5.x and vxWorks 6.x kernel.
Sure; in this case the branch would only be needed to give you the two
separate build trees, until you can get the vxWorks 5.5.x IOCs upgraded
to vxWorks 6.x - I'm assuming that this would be one of the main points
of introducing vxWorks 6 IOCs in the first place. As I said, it also
gives the engineer responsible for the IOC area an incentive to upgrade
his/her IOCs quickly...
However, in the case of a "share top" which contains drivers such as
vxStats there will be an impact. So, vxStats is riddle with "ifdefs" or
a new branch is made. In the case of vxStats we will be working on some
abstraction layer to hide vxWorks API changes.
Actually I would expect vxStats to be the one support application that
really would have to be different for different versions of vxWorks,
since it probably relies on the OS APIs that tend to be on the fringes
of normal functionality and thus change between major versions. The
advantage of starting a new IOC branch in this case is that you can link
to a completely different vxStats support application for vxWorks 6, and
you wouldn't need any of the ifdef stuff or an abstraction layer at all
(Actually you can do that with a different target architecture too, you
just have to create a configure/RELEASE.Common.vxWorks6-ppc604_long file
in each IOC area to override the configure/RELEASE setting).
The compiler options are actually CPU specific and BSP specific.
One example is the altivec support, but you already handle this with an
altivec suffix in the target name. I agree that the options may not be
necessary always.
Adding the altivec really makes it a different CPU, so it has to be a
different target architecture. I'd be interested in any other examples
you can find though.
- Andrew
The right to be heard does not automatically include
the right to be taken seriously. -- Hubert H. Humphrey
- RE: EPICS R3.14.9 and vxWorks Thompson, David H.
- Re: EPICS R3.14.9 and vxWorks Ernest L. Williams Jr.
- EPICS R3.14.9 and vxWorks Ernest L. Williams Jr.
- Re: EPICS R3.14.9 and vxWorks Andrew Johnson
<2007>
2025
2026
<2007>
2025
2026
