2002  2003  2004  2005  2006  <20072008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 2002  2003  2004  2005  2006  <20072008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Bug in IOC "local" time
To: EPICS Core Talk <[email protected]>
Date: Sat, 12 May 2007 00:04:34 +0200
I think I found something that smells like a bug in the vxWorks "local" clock (or in libCom/osi/os/vxWorks/iocClock).
When the TIMEZONE environment variable gets set through configure/CONFIG_SITE_ENV in base, everything works as expected.
When I set the TIMEZONE variable to the exact same value from the startup script (at the very beginning), the iocClock (i.e. the "local" IOC time when calling "date" in the VxWorks shell) always returns
  2038/01/19 04:14:08.nnnn
where only the split second is changing, as if the "seconds since the epoch" are constant and only the nanoseconds count up. The same applies to the "local" time generated by a stringin record with "Soft Timestamp" support: Correct string if TIMEZONE originates from CONFIG_SITE_ENV, January 2038 if set in the startup script. The timestamps that CA delivers cross network are coherent and correct. only local conversion seems to be affected.
The behaviour is exactly the same when using apsEvent 1.1 (the 3.14 version of the TS... module) in soft slave mode instead of the iocClock from libCom.
I don't see anything obviously stupid in libCom/osi/os/vxWorks/iocClock.c.
System: VxWorks 5.4.2, EPICS 3.14.8.2, MV2100
Is someone able to test and/or confirm this behaviour?
Cheers,
Ralph
Re: Bug in IOC "local" time Andrew Johnson
Prev: RE: generalTime & EventTime Kalantari Babak
Next: Re: Bug in IOC "local" time Andrew Johnson
Index: 2002  2003  2004  2005  2006  <20072008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
