2002  2003  2004  2005  2006  <20072008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 2002  2003  2004  2005  2006  <20072008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: Mutex error on recent Redhat systems
To: Kay-Uwe Kasemir <[email protected]>
Cc: "'EPICS core-talk'" <[email protected]>
Date: Fri, 18 May 2007 15:32:50 -0500
Hello Kay,
Kay-Uwe Kasemir wrote:
Looks like the onceLock used by epicsThreadOnceOsd() needs to be
initialized by a proper call to epicsThreadInit(), which calls
once(), which performs pthread_mutex_init(&onceLock,0).
Then it's destroyed later from an atExit routine.
Maybe that doesn't happen at the correct time, so the bad status
is the result of a destroyed mutex?
That is my initial guess as to what's happening. However until I've instrumented the thing better and run it on Fedora-6 I can't be sure.
Maybe one could simply use static initialization of the onceLock, i.e.:
static pthread_mutex_t onceLock = PTHREAD_MUTEX_INITIALIZER;
That way, there's no need to specifically create nor destroy it.
Unfortunately we can't use static initialization because C++ doesn't guarantee the relative order of initialization of objects in different translation units that might rely on each other (ISO C++ standard, section 3.6.2). We found that code in an initializer in one source file was calling code in another file before the second files' static initializers had been run, which was causing major problems. That's the whole purpose of the epicsThreadOnce() stuff that Jeff and Marty had to put in, to have our own mechanism for initialization that we could control.
- Andrew
The right to be heard does not automatically include
the right to be taken seriously. -- Hubert H. Humphrey
Re: Mutex error on recent Redhat systems Andrew Johnson
RE: Mutex error on recent Redhat systems Jeff Hill
Re: Mutex error on recent Redhat systems Kay-Uwe Kasemir
Prev: Re: Mutex error on recent Redhat systems Kay-Uwe Kasemir
Next: Howto set or read one value of a waveform record Touchard Dominique
Index: 2002  2003  2004  2005  2006  <20072008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
