2002  2003  2004  2005  2006  <20072008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 2002  2003  2004  2005  2006  <20072008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: FW: net_convert.h
To: Jeff Hill <[email protected]>
Cc: [email protected]
Date: Tue, 17 Jul 2007 12:04:01 -0500
Hi Jeff,
> I tried to login to mantis this morning and I am also experiencing
> troubles.
Unfortunately Mantis is currently broken; the version we're using is very old, and pre-dates PHP5, which our webserver was upgraded to last week.  I thought I had tested it before they did the upgrade, but I must have missed something and I haven't had a chance to investigate in detail yet.
The worst-case scenario is that I may have to replace Mantis with something else, which will mean trying to convert the existing bug database — an upgrade to the latest version of Mantis probably falls into that category too since I think it has changed quite a bit since our version. If I do have to replace it, I will endevour to keep as much of our existing bug history as I can, but I can't promise that everything will copy over.
Any suggestions for a web-based bug-tracker using a MySQL database from any core-talk readers?  I'm certainly interested in Trac and would be open to other suggestions, but don't say Bugzilla, it's too hard to configure.
- Andrew
Prev: Re: 3.13. Device support report() documentation bug Andrew Johnson
Next: Record fields of array type Benjamin Franksen
Index: 2002  2003  2004  2005  2006  <20072008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
