I'm having a little trouble using epicsTimeDiffInSeconds().
src/libCom/osi/epicsTime.cpp:970 in R3.14.9
Whilst it should be straightforward, I'm getting some strange results
that I hope someone can shed light on.
The trace below is triggered when epicsTimeDiffInSeconds(new, last)
returns a -ve number. I've printed the secsSinceEpoch and nsec fields of
each of the epicsTimeStamp structures. 'diff' is the return value from
the function call. I've also printed DBL_MAX, which should be
1.7976931348623157e+308, but isn't.
0x1ec5ab00 (scan0.1): TCP provider "MRF EVR" provides backwards time!
new = 562760425s, 0ns, last = 562760425s, 983327000ns
diff=-2.28999e+226
0x1ec5ab00 (scan0.1): DBL_MAX is -2.28999e+226
0x1ec48800 (timerQueue): TCP provider "MRF EVR" provides backwards time!
new = 562760479s, 583936000ns, last = 562760479s, 583937000ns
diff=-2.28999e+226
0x1ec48800 (timerQueue): DBL_MAX is -2.28999e+226
It appears that there are two problems: 1) somewhere in the bowels of
the construction of 2 C++ objects, and calling operator- there is an
exception being raised, causing the function to return -DBL_MAX. 2)
Somehow the vxWorks compiler (gcc 2.96) is failing to represent DBL_MAX
properly.
Any clues? I'm sure there were very good reasons to do all the time code
in C++, but it seems to be confusing rather than helping at the moment.
Peter Denison, Senior Software Engineer, Diamond Light Source Ltd.
Tel: +44 1235 778511
(apologies in advance for the lines below. Some bits are a legal
requirement and I have no control over them)
<DIV><FONT size="1" color="gray">This e-mail and any attachments may contain confidential, copyright and or privileged material, and are for the use of the intended addressee only. If you are not the intended addressee or an authorised recipient of the addressee please notify us of receipt by returning the e-mail and do not use, copy, retain, distribute or disclose the information in or attached to the e-mail.
</FONT></DIV>
- RE: epicsTime.cpp Strangeness Denison, PN (Peter)
Re: GNU make multiple jobs option Andrew Johnson
<2007>
2025
2026
<2007>
2025
2026
