Liu, Gongfa wrote:
(8) base-3.14.9/src/libCom/osi/epicsThread.h
The function epicsThreadDelete is declared.
(11) base-3.14.9/src/libCom/osi/os/posix/osdThread.c
The function epicsThreadDelete is implemented.
(15) base-3.14.9/src/libCom/osi/os/vxWorks/osdThread.c
The function epicsThreadDelete is just used for RMT. We will give it up
and change the relevant codes.
Ok, I will delete those file changes from the libCom patch.
(9) base-3.14.9/src/libCom/osi/epicsTime.h
The function epicsTimeGetTicks is declared.
(12) base-3.14.9/src/libCom/osi/os/posix/osdTime.cpp
The function epicsTimeGetTicks is implemented.
(13) base-3.14.9/src/libCom/osi/os/vxWorks/iocClock.c
RMT code is vxWorks dependent originally and tickGet() is used. We will
give it up and change the relevant codes.
I will delete those file changes from the libCom patch too.
- Andrew
When a distinguished but elderly scientist states that something is
possible, he is almost certainly right. When he states that something
is impossible, he is very probably wrong. -- Arthur C. Clarke
- Redundancy Patch: libCom Andrew Johnson
- Re: Redundancy Patch: libCom Andrew Johnson
- Re: Redundancy Patch: libCom Liu, Gongfa
Re: Redundancy Patch: iocsh Andrew Johnson
[Fwd: Re: Timing/Event Systems] Andrew Johnson
<2007>
2025
2026
Redundancy Patch: db Andrew Johnson
<2007>
2025
2026
