2002  2003  2004  2005  2006  2007  <20082009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 2002  2003  2004  2005  2006  2007  <20082009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: NDEBUG
To: [email protected]
Date: Fri, 25 Apr 2008 20:01:22 +0200
On Freitag, 25. April 2008, Andrew Johnson wrote:
> Jeff Hill wrote:
> > 2) Standardize throughout base on a new flag controlling the removal of
> > high overhead consistency checking code and set this flag by default in
> > production (optimized) builds.
> If you're thinking about adding some expensive consistency checking that
> will significantly affect performance when enabled then I fully agree to
> having them disabled in production builds.  However I don't particularly
> like the idea of having them enabled whenever the OPT flag is off, since
> it then becomes hard to separate out bugs that are caused by a compiler
> when optimization is turned on; I'd much prefer a separate switch which
> can be set on a per-subsystem or even per-compilation unit basis,
> separate from the compiler optimization switch.
Yes, definitely. Make it a separate global flag, easily (un-)settable in
CONFIG_SITE*. Beside your argument about optimization induced bugs, it is
important that users can test per application how great the performance
gain really is and decide for themselves whether it is worth the loss in
debugability.
Cheers
Ben
Re: NDEBUG Andrew Johnson
Prev: Re: NDEBUG Andrew Johnson
Next: Re: Unresolved symbol: rtemsTicksPerSecond_double Andrew Johnson
Index: 2002  2003  2004  2005  2006  2007  <20082009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
