2002  2003  2004  2005  2006  2007  <20082009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 2002  2003  2004  2005  2006  2007  <20082009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: Unresolved symbol: rtemsTicksPerSecond_double
To: Till Straumann <[email protected]>
Cc: Steve Shoaf <[email protected]>, Arturo Alarcon <[email protected]>, EPICS core-talk <[email protected]>, "Ernest L. Williams Jr." <[email protected]>, [email protected]
Date: Fri, 2 May 2008 10:31:57 -0500
On May 2, 2008, at 10:22 AM, Till Straumann wrote:
It just seems that rtems_netconfig.c mixes functionality of initializing RTEMS (networking, console, ...) and initializing EPICS (some generic things, some
os/RTEMS specific).
How so?
As far as I can tell, rtems_netconfig.c contains nothing but the network configuration structures.
At least that's all that I intended it to contain.
IMO it would be useful to break the two apart so that users implementing their own RTEMS initialization can still use the pieces that deal with initializing
EPICS (w/o having to copy/paste from rtems_netconfig.c)
For network configuration, the hooks mentioned in the release notes should be all that's needed to implement custom tweaks (no copying of rtems_netconfig.c required). For example, our BPM embedded IOCs set all their network configuration based on the setting of front-panel switches.
There are no corresponding hooks for RTEMS configuration at the moment, though.
- Till
- Andrew
Eric Norum wrote:
There are some mechanisms already available.
1) EPICS RTEMS support breaks the configuration/initialization into several source files. If, for example, your application requires some specialized network configuration, simply copy rtems_netconfig.c to the application directory, make the changes, and add rtems_netconfig.c to the application Makefile. To do this on a site-wide basis, put your site-specific version of rtems_netconfig.o into a support module where it will be linked before -lrtemsCom is encountered. There's a separate rtems_config.c file, too.
2) As noted in the EPICS R3.14.10 release notes, there are some hooks to make it easier to set up your own specific configuration:
Added hooks for application routines to supply special network configuration parameters. The RTEMS startup code calls epicsRtemsInitPreSetBootConfigFromNVRAM just before reading values from NVRAM and epicsRtemsInitPostSetBootConfigFromNVRAM just afterwards. See epicsRtemsInitHooks.h for prototypes and global variables.
seems that 3.14.10 does a more initialization in the 'Init' function which we don't use (e.g., because it hardcodes things like the the
amount of mbuf  (networking buffers) space [which ends up
being the same] and whether BOOTP should be used.
IMHO we should come up with a better way of initializing the system that is more flexible (here we use a bootloader plus a small library for connecting the bootloader, user interactive input, non- volatile memory
and the bootee).
For the time being, IMHO 'Init' should be broken up into pieces
that
a) deal with initializing RTEMS (networking, filesystem, console)
b) deal with initializing EPICS (setting some environment variables,
  rtemsTicksPerSecond_double etc.)
The user should be able to override all of (a) but use (b) to initialize
EPICS on an RTEMS system of her preference.
That seems entirely reasonable, can you work with Eric to come up with a proposal and patch that works for both camps? R3.14.10 is not set in stone yet, and it would be good to get this cleared up before the release.
- Andrew
Eric Norum <[email protected]>
Advanced Photon Source
Argonne National Laboratory
(630) 252-4793
Re: Unresolved symbol: rtemsTicksPerSecond_double Till Straumann
Re: Unresolved symbol: rtemsTicksPerSecond_double Andrew Johnson
Prev: Re: Unresolved symbol: rtemsTicksPerSecond_double Till Straumann
Next: Re: Unresolved symbol: rtemsTicksPerSecond_double Till Straumann
Index: 2002  2003  2004  2005  2006  2007  <20082009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
