Hi Artem,
Artem Kazakov wrote:
I recall that you've showed me that on some of the machines my ruby
script was waiting for the output from the caputackt command, while
the latter being zombie.
So yesterday encountered the same behavior on my Mac-box. And the
funny thing is that if I start caRepeater as separate independent
process, everything works as supposed.
But if the caRepeater is not running, then it is started somewhere
from ca library (I guess?) and then there is a zombie walking around
and caRepeater process is still running.
If I kill that spawned caRepeater process by hand, than zombie finally
dies and script continues until next caLib using command (such as
caput) and then again there is a zombie and caRepeater.
Is it supposed to be like that ?
I'm not so familiar with the ca lib internals and caRepeater
interaction, but may be you can get give me a hint on what's going on?
If there is no caRepeater running on the machine, a CA client program
will start one when it initializes the CA library. The preferred method
is to fork() and execlp() the external caRepeater program, but if it
can't find caRepeater in $PATH the child process will print a warning
and run the repeater functionality itself. Do you have a copy of
caRepeater in your $PATH? I suspect not, and that if you did you'd find
the zombie would not appear — please confirm that if possible.
What are the parent processes of the caRepeater and of the zombie?
However just copying caRepeater into your $PATH won't resolve the
fundamental issue that somehow it's generating zombies. I'm not sure
how, but it obviously can. I double-checked the src/libCom/osi/os/posix
code that makes the fork()/execlp() calls; it is not getting the child
and parent processes mixed up.
- Andrew
Talk is cheap. Show me the code. -- Linus Torvalds
- Re: zombies Artem Kazakov
Re: CR/CSR support in EPICS Andrew Johnson
<2008>
2025
2026
<2008>
2025
2026
