2002  2003  2004  2005  2006  2007  <20082009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 2002  2003  2004  2005  2006  2007  <20082009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: SLAC RTEMS and libCom test harness
To: EPICS core-talk <[email protected]>
Date: Tue, 16 Sep 2008 20:21:06 -0700
Target:  MVME6100
OS:       RTEMS 4.9 snapshot
EPICS: R3.14.10-pre1
How to run the test Harness for our style of RTEMS at SLAC?
Also, still getting the conflicting message about NTP.
Any suggestions?
< st.cmd
<'st.cmd':
   ## Example RTEMS startup script
   ## You may have to change muon to something else
   ## everywhere it appears in this file
   #< envPaths
   chdir("../..")
0x00000000 (0)
   # Load application object file.
   ld("bin/RTEMS-beatnik/muon.obj")
0x009c89b8 (10258872)
   dbLoadDatabase("dbd/muon.dbd")
0x00000000 (0)
   muon_registerRecordDeviceDriver(pdbbase)
0x00000000 (0)
   ## Load record instances
   dbLoadRecords("db/dbExample1.db","user=ernesto")
0x00000000 (0)
   dbLoadRecords("db/dbExample2.db","user=ernesto,no=1,scan=1 second")
0x00000000 (0)
   dbLoadRecords("db/dbExample2.db","user=ernesto,no=2,scan=2 second")
0x00000000 (0)
   dbLoadRecords("db/dbExample2.db","user=ernesto,no=3,scan=5 second")
0x00000000 (0)
   dbLoadRecords("db/dbSubExample.db","user=ernesto")
0x00000000 (0)
   dbLoadRecords("db/iocAdmin-template.db","IOCNAME=muon")
0x00000000 (0)
   ## Set this to see messages from mySub
   #var mySubDebug 1
   iocInit()
Starting iocInit
## EPICS R3.14.10--lcls1 $$Name: R3-14-2_branch $$ $$Date: 2008/09/16 16:32:45 $$
## EPICS Base built Sep 16 2008
0x00000000 (0)
   bspExtVerbosity=0
0x00000000 (0)
   ## Start any sequence programs
   seq(&sncExample,"user=ernesto")
SEQ Version 2.0.11: Tue Sep 16 19:33:35 2008
Spawning state program "sncExample", thread 0xa010022: "sncExample"
0x0a010022 (167837730)
Cexp>rtems_bsdnet_get_ntp() Can't bind socket: Address already in use
Cexp>ld("../../base/base-R3-14-10/bin/RTEMS-beatnik/rtemsTestHarness.obj")
Symbol 'epicsThreadGetPrioritySelf' already exists
Symbol 'epicsTimeFromTime_t' already exists
Symbol 'epicsSnprintf' already exists
Ernest
Prev: libCom tests and a softIOC on Linux hosts Ernest L. Williams Jr.
Next: vxWorks 6.6 and EPICS R3.14.10-pre1 libCom Test Harness Ernest L. Williams Jr.
Index: 2002  2003  2004  2005  2006  2007  <20082009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
