2002  2003  2004  2005  2006  2007  2008  <2009>  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 2002  2003  2004  2005  2006  2007  2008  <2009>  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Do we have any plan to support non-fixed size array?
To: [email protected]
Date: Mon, 19 Jan 2009 18:01:46 +0800
Hey guys,
Currently, if we dealing with array, its max length is determined at "compile-time" as specified by environment variable EPICS_CA_MAX_ARRAY_BYTES, this means we can't change the max array length when a CA client is built. If this client connects an IOC supports larger size of arrays, we need to rebuild the client. So do we have any plan to support non-fixed size array?
Alex
Re: Do we have any plan to support non-fixed size array? Andrew Johnson
Prev: Re: makeBaseApp.pl Andrew Johnson
Next: Re: Do we have any plan to support non-fixed size array? Andrew Johnson
Index: 2002  2003  2004  2005  2006  2007  2008  <2009>  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
