2002  2003  2004  2005  2006  2007  2008  <2009>  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 2002  2003  2004  2005  2006  2007  2008  <2009>  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: wrong timestamps in monitors
To: EPICS Core Talk <[email protected]>
Date: Thu, 29 Jan 2009 15:42:12 +0100
One more aspect of this issue: currently the record timestamp is put on all PVs that belong to the record, even though CA has no concept of a record that would match this relation.
So - why not put this on the list of possible work packages for the next codeathon?
Definitely something worth to be fixed, changing a behaviour that no one should rely on (does someone?), and there are ways to improve this that do not need a lot of changes in the code once we agree on how this should be handled.
What do you think?
Ralph
On 29.01.2009 14:46 Benjamin Franksen wrote:
I think this is a known issue, it is at least as old as 3.13.9. EPICS posts CA events when a non-VAL fields get written to, and it does so independently of record support. There are two cases:
- If the field does not have the PP property, then the record is not processed as a result of the put, and the CA event is posted with the old timestamp.
- If the field /does/ have the PP property, then the record gets processed as a result of the put, which woudl update the record's timestamp, but processing comes /after/ EPICS base posts the event, thus the event has the wrong (old) timestamp.
It should be clear that this means one should /not/ trust the history of value changes as e.g. reported by the channel archiver (or simply the output of camonitor) whenever the PV in question references a non-VAL field. At least not w.r.t. the reported timestamps.
Is this going to be addressed any time soon?
Cheers
Ben
Prev: RE: Do we have any plan to support non-fixed size array? Jeff Hill
Next: EPICS and interruptable system calls Mark Rivers
Index: 2002  2003  2004  2005  2006  2007  2008  <2009>  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
