2002  2003  2004  2005  2006  2007  2008  <2009>  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 2002  2003  2004  2005  2006  2007  2008  <2009>  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: String hash functions and resourceLib.h
To: Jeff Hill <[email protected]>
Cc: Core-Talk <[email protected]>
Date: Mon, 23 Mar 2009 16:14:12 -0500
Hi Jeff,
I've been looking at string hash functions, and have recently replaced Marty's
(as used in both gpHash and dbPvd) with one that is faster and performs as
well on most IOCs and somewhat better on many.  The function is now available
from epicsString.h, and I think we should use it in resourceLib.h as well.
Unfortunately your hash function generates rather a lot of collisions with
some loads, and as with Marty's function it does require a table look-up for
every character, which slows it down compared to the pure CPU methodologies.
Here are the results of my tests, showing for each algorithm a histogram
showing how many buckets contain a specific number of items.  Of the
algorithms, "mrk" is Marty's original, and 'joh' is the stringId::hash
algorithm from resourceLib.h.  The algorithm I picked for epicsString.c
is "ap" by Arash Partow, which along with some of the others is described at
http://www.partow.net/programming/hashfunctions/
tux% bin/linux-x86_64/hash /usr/local/iocapps/iocinfo/pvdata/iocpss05bm 6
Read 14896 items into 16384 buckets, averaging 0.909 items per bucket
Algorithm:    mrk   joh    ap  sdbm   djb    rs bkdr1 bkdr2 bkdr3 bkdr4 bkdr5
      0      6824  8871  6219  6705  7245  6339  6694  6358  7238  6380  6447
      1      5729  4486  6471  5858  5140  6316  5869  6292  5296  6242  6157
      2      2661  1501  2839  2727  2674  2796  2725  2813  2541  2835  2837
      3       905   542   699   846   979   768   850   737   877   756   745
      4       206   274   131   203   273   141   207   156   299   141   165
      5        51   231    24    37    61    24    35    25   107    28    28
      6         5   178     1     7    10     0     4     3    26     2     5
      7         3   133     0     1     2     0     0     0     0     0     0
      8         0    69     0     0     0     0     0     0     0     0     0
      9         0    52     0     0     0     0     0     0     0     0     0
     10         0    26     0     0     0     0     0     0     0     0     0
     11         0     8     0     0     0     0     0     0     0     0     0
     12         0     9     0     0     0     0     0     0     0     0     0
     13         0     2     0     0     0     0     0     0     0     0     0
     14         0     0     0     0     0     0     0     0     0     0     0
     15         0     2     0     0     0     0     0     0     0     0     0
Std.Dev.    0.987 1.594 0.896 0.968 1.040 0.911 0.964 0.916 1.064 0.917 0.928
FigOfMerit  0.984 1.547 0.901 0.967 1.032 0.915 0.963 0.920 1.054 0.920 0.931
FoM Rank        7    10     0     6     8     1     5     2     9     3     4
The input data for the above test is the record list from our IOC with the
largest number of records.  I have run this against many other IOC record
lists, adjusting the table size appropriately, and the "ap" algorithm usually
appears at or near the top.  The source for my test program is attached; the
second argument sets the table size and should be between 0 and 8.
I would be happy to commit the necessary changes to resourceLib.h if you wish
me to.
- Andrew
The best FOSS code is written to be read by other humans -- Harold Welte
/* hash.cpp */
#include <stddef.h>
#include <stdlib.h>
#include <stdio.h>
#include <string.h>
#include <math.h>
#define NELEMENTS(arr) (sizeof arr / sizeof arr[0])
#define MAX_PV_NAME_LEN 61
typedef unsigned char uint8_t;
int bitshift;
 * Hash functions to test
static const uint8_t T[256] = {
     39,159,180,252, 71,  6, 13,164,232, 35,226,155, 98,120,154, 69,
    157, 24,137, 29,147, 78,121, 85,112,  8,248,130, 55,117,190,160,
    176,131,228, 64,211,106, 38, 27,140, 30, 88,210,227,104, 84, 77,
     75,107,169,138,195,184, 70, 90, 61,166,  7,244,165,108,219, 51,
      9,139,209, 40, 31,202, 58,179,116, 33,207,146, 76, 60,242,124,
    254,197, 80,167,153,145,129,233,132, 48,246, 86,156,177, 36,187,
     45,  1, 96, 18, 19, 62,185,234, 99, 16,218, 95,128,224,123,253,
     42,109,  4,247, 72,  5,151,136,  0,152,148,127,204,133, 17, 14,
    182,217, 54,199,119,174, 82, 57,215, 41,114,208,206,110,239, 23,
    189, 15,  3, 22,188, 79,113,172, 28,  2,222, 21,251,225,237,105,
    102, 32, 56,181,126, 83,230, 53,158, 52, 59,213,118,100, 67,142,
    220,170,144,115,205, 26,125,168,249, 66,175, 97,255, 92,229, 91,
    214,236,178,243, 46, 44,201,250,135,186,150,221,163,216,162, 43,
     11,101, 34, 37,194, 25, 50, 12, 87,198,173,240,193,171,143,231,
    111,141,191,103, 74,245,223, 20,161,235,122, 63, 89,149, 73,238,
    134, 68, 93,183,241, 81,196, 49,192, 65,212, 94,203, 10,200, 47
int mrk(const char *str, int length)
    const int n = length & ~1;
    uint8_t h0 = 0;
    uint8_t h1 = 0;
    int i;
    if (length & 1)
        h0 = T[h0 ^ str[n]];
    for (i = 0; i < n; i += 2) {
        h0 = T[h0 ^ *str++];
        h1 = T[h1 ^ *str++];
    return ((int)h1 << bitshift) ^ h0;
int joh(const char *str, int length)
    const unsigned char *pUStr = reinterpret_cast<const unsigned char *>(str);
    unsigned h0 = 0;
    unsigned h1 = 0;
    unsigned h2 = 0;
    unsigned h3 = 0;
    unsigned c;
    while (1) {
        if ((c = *pUStr++) == 0) break;
        h0 = T[h0 ^ c];
        h1 = T[h1 ^ c];
        h2 = T[h2 ^ c];
        h3 = T[h3 ^ c];
    size_t hash = (h3 << 24) | (h2 << 16) | (h1 << 8) | h0;
    unsigned width = 32;
    do {
        width >>= 1u;
        hash ^= hash >> width;
    } while (width > 8);
    return hash;
int ap(const char *str, int length)
    unsigned int hash = 0;
    while (length-- > 0) {
        hash ^= ~((hash << 11) ^ *str++ ^ (hash >> 5));
        if (!(length-- > 0)) break;
        hash ^= (hash << 7) ^ *str++ ^ (hash >> 3);
    return hash;
int rs(const char *str, int length)
    int a = 63689, b = 378551;
    int hash = 0;
        hash = hash * a + *str++;
        a *= b;
    return hash;
int js(const char *str, int length)
    int hash = 1315423911;
        hash ^= ((hash << 5) + (hash >> 2) + *str++);
    return hash;
int muladd(const char *str, int length, int hash, int mul)
        hash = hash*mul + *str++;
    return hash;
int bkdr1(const char *str, int length)
    return muladd(str, length, 0, 31);
int bkdr2(const char *str, int length)
    return muladd(str, length, 0, 131);
int bkdr3(const char *str, int length)
    return muladd(str, length, 0, 1313);
int bkdr4(const char *str, int length)
    return muladd(str, length, 0, 13131);
int bkdr5(const char *str, int length)
    return muladd(str, length, 0, 131313);
int sdbm(const char *str, int length)
    return muladd(str, length, 0, 65599);
int djb(const char *str, int length)
    return muladd(str, length, 5381, 33);
/* Test structure */
typedef int (*HASHFUNC)(const char *, int);
#define h(f) {#f, f}
static struct {
    char *name;
    HASHFUNC func;
} hashes[] = {
    h(mrk),
    h(joh),
    h(ap),
    h(sdbm),
    h(djb),
    h(rs),
    h(bkdr1),
    h(bkdr2),
    h(bkdr3),
    h(bkdr4),
    h(bkdr5),
#define NALGORITHMS ((int)NELEMENTS(hashes))
int main(int argc,char **argv)
    if (argc != 3) {
        fprintf(stderr, "usage: hash filename shift\n");
        exit(1);
    bitshift = atoi(argv[2]);
    if (bitshift < 0 || bitshift > 8) {
        printf("hash: shift parameter must be between 0 and 8\n");
        exit(1);
    int nBuckets = (256 << bitshift);
    unsigned mask = (nBuckets - 1);
    unsigned bucket[nBuckets][NALGORITHMS];
    for (int h = 0; h < nBuckets; h++)
        for (int alg = 0; alg < NALGORITHMS; alg++)
            bucket[h][alg] = 0;
    FILE *fp = fopen(argv[1], "r");
    if (!fp) {
        perror("hash");
        exit(1);
    unsigned items = 0;
    unsigned largest = 0;
    while(!feof(fp)) {
        char tempStr[MAX_PV_NAME_LEN];
        char *pstr = fgets(tempStr, MAX_PV_NAME_LEN, fp);
        if (!pstr) break;
        int len = strlen(pstr);
        if (len <= 1) continue;
        pstr[--len] = 0; /* Ignore trailing newline */
        items++;
        for (int alg = 0; alg < NALGORITHMS; alg++) {
            int hash = hashes[alg].func(pstr, len) & mask;
            unsigned b = ++bucket[hash][alg];
            if (b > largest) largest = b;
    fclose(fp);
    if (items == 0) {
        printf("File empty\n");
        exit(0);
    printf("Read %u items into %d buckets, averaging %.3f items per bucket\n\n",
        items, nBuckets, (double)items / nBuckets);
    const unsigned nfreqs = largest + 1;
    unsigned freq[NALGORITHMS][nfreqs];
    double X[NALGORITHMS] = {0.0};
    double XX[NALGORITHMS] = {0.0};
        for (unsigned k = 0; k < nfreqs; k++)
            freq[alg][k] = 0;
    for (int h = 0; h < nBuckets; h++) {
            unsigned count = bucket[h][alg];
            ++freq[alg][count];
            if (count) {
                X[alg] += count;
                XX[alg] += count * count;
    double stdDev[NALGORITHMS];
        double mean = X[alg] / items;
        stdDev[alg] = sqrt(XX[alg] / items - mean * mean);
    double F[NALGORITHMS] = {0.0};
    double FF[NALGORITHMS] = {0.0};
        for (unsigned k = 0; k < nfreqs; k++) {
            double f = k*freq[alg][k];
            F[alg] += f;
            FF[alg] += f * k;
    double fom[NALGORITHMS];
    unsigned rank[NALGORITHMS] = {0};
        double mean = F[alg] / nBuckets;
        fom[alg] = sqrt(FF[alg] / nBuckets - mean * mean);
        for (int j = 0; j < alg; j++)
            if (fom[j] != fom[alg])
                (fom[j] > fom[alg]) ? ++rank[j] : ++rank[alg];
    printf("Algorithm:");
        printf(" %5s", hashes[alg].name);
    printf("\n");
    for (unsigned u = 0; u < nfreqs; u++) {
        printf(" %6u   ", u);
            printf(" %5u", freq[alg][u]);
        printf("\n");
    printf("\n");
    printf("Std.Dev.  ");
        printf(" %5.3f", stdDev[alg]);
    printf("\n");
    printf("FigOfMerit");
        printf(" %5.3f", fom[alg]);
    printf("\n\n");
    printf("FoM Rank  ");
        printf(" %5u", rank[alg]);
    printf("\n");
    return 0;
RE: String hash functions and resourceLib.h Jeff Hill
Prev: RE: SIGALRM => SIGUSR1? Jeff Hill
Next: RE: String hash functions and resourceLib.h Jeff Hill
Index: 2002  2003  2004  2005  2006  2007  2008  <2009>  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
