2002  2003  2004  2005  2006  2007  2008  <20092010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 2002  2003  2004  2005  2006  2007  2008  <20092010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: Base R3.14.11-pre1 available for testing
Cc: Core-Talk <[email protected]>, Till Straumann <[email protected]>
Date: Tue, 21 Jul 2009 09:19:06 -0700
Hi Andrew,
Is the following really true:
       RTEMS Release
RTEMS release 4.9.2 or newer is required. EPICS now configures RTEMS to use unified executive/malloc memory pools if available (RTEMS 4.10 and up).
If so, I will ask Till to bring us up to RTEMS 4.9.2 as current we have rtems 4.9.1.
Ernest
Andrew Johnson wrote:
The first pre-release version of Base 3.14.11 is now available for download and testing, see http://www.aps.anl.gov/epics/base/R3-14/11.php for details.
I have not uploaded the Application Developers Guide yet, I'll try to get that done this week. If you can, please check out this version and report any bugs you find here on core-talk. If all goes well the 3.14.11-RC1 release can be created on August 3rd (which will be announced on tech-talk) and the final release on August 10th.
- Andrew
Re: Base R3.14.11-pre1 available for testing Eric Norum
Base R3.14.11-pre1 available for testing Andrew Johnson
Prev: Base R3.14.11-pre1 available for testing Andrew Johnson
Next: Re: Base R3.14.11-pre1 available for testing Eric Norum
Index: 2002  2003  2004  2005  2006  2007  2008  <20092010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
