2002  2003  2004  2005  2006  2007  2008  <20092010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 2002  2003  2004  2005  2006  2007  2008  <20092010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: dbPutString has a magic number
To: <[email protected]>
Date: Wed, 16 Dec 2009 12:25:31 -0500
Several months ago it was pointed out to me that dbPutString in src/dbStatic/dbStaticLib.c uses a fixed length buffer when processing Link strings.  This buffer is defined as 'char string[80];'.  This is apparently the limit on the length of a string which can be passed to device support.  In this particular case the issue was a device support for accessing SNMP which apparently can have some really long names.
Attached is a patch which replaces this with a dynamically allocated string buffer.  I originally avoided doing the allocation, but the result had some strange string manipulations which seem ripe for off-by-one errors.  I can't quite bring myself to submit it.
I'm not certain if this is the correct solutions, but here it is.
Michael
From 1ddc3f7c92e49a62ee54caa70e780ad2d65d2a4a Mon Sep 17 00:00:00 2001
Date: Wed, 16 Dec 2009 11:51:57 -0500
Subject: dbPutString: Don't use a fixed length string buffer
 src/dbStatic/dbStaticLib.c |   11 ++---------
 1 files changed, 2 insertions(+), 9 deletions(-)
diff --git a/src/dbStatic/dbStaticLib.c b/src/dbStatic/dbStaticLib.c
index 47d75b7..39c743f 100644
--- a/src/dbStatic/dbStaticLib.c
+++ b/src/dbStatic/dbStaticLib.c
@@ -2202,8 +2202,7 @@ long epicsShareAPI dbPutString(DBENTRY *pdbentry,const char *pstring)
     case DBF_OUTLINK:
     case DBF_FWDLINK: {
 	    DBLINK	*plink;
-	    char	string[80];
-	    char	*pstr = string;
+	    char	*pstr = NULL;
 	    int		ind;
 	    if (!pfield)
@@ -2225,13 +2224,7 @@ long epicsShareAPI dbPutString(DBENTRY *pdbentry,const char *pstring)
 		    return status;
-	    if (strlen(pstring) >= sizeof(string)) {
-	        status = S_dbLib_badField;
-	        errMessage(status,
-			"dbPutString received a string that is too long");
-	        return status;
-	    strcpy(pstr, pstring);
+	    pstr=epicsStrDup(pstring);
 	    /* Strip leading blanks and tabs */
 	    while (*pstr && (*pstr == ' ' || *pstr == '\t')) pstr++;
 	    /* Strip trailing blanks and tabs */
1.6.3.3
Prev: RE: multiple NTP servers and NTPTime Kalantari Babak
Next: CVS migration to Bazaar Andrew Johnson
Index: 2002  2003  2004  2005  2006  2007  2008  <20092010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
