2002  2003  2004  2005  2006  2007  2008  <2009>  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 2002  2003  2004  2005  2006  2007  2008  <2009>  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Base CVS Converted to Bazaar
To: "EPICS core-talk" <[email protected]>
Date: Wed, 23 Dec 2009 15:42:16 -0600
The epics/base history has been successfully converted from CVS to Bazaar and
uploaded to https://launchpad.net/epics-base
You will need to install a recent copy of the Bazaar DVCS software to make use
of this for development, although launchpad provides the ability to browse the
files and their revision history using a regular web browser.
Advice on how to use Bazaar for EPICS Base can be found on this Wiki page:
  http://www.aps.anl.gov/epics/wiki/index.php/How_to_check_out_EPICS_Base_with_Bazaar
There are three release series branches published:
    lp:epics-base/3.12    Contains the 3.12 releases
    lp:epics-base/3.13    Contains the 3.13 releases
    lp:epics-base/3.14    Contains the 3.14 releases
The history from the CVS main trunk is available at
    lp:~epics-core/epics-base/cvs-trunk
but may be subject to some reorganization in the future.
Jeff: Continue developing against the cvs-trunk branch, I'm not going to do
anything significant with this until January 4th at the earliest.
- Andrew
The best FOSS code is written to be read by other humans -- Harald Welte
Prev: RE: september cut Jeff Hill
Index: 2002  2003  2004  2005  2006  2007  2008  <2009>  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
