2002  2003  2004  2005  2006  2007  2008  2009  <20102011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 2002  2003  2004  2005  2006  2007  2008  2009  <20102011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Bug in macLib
To: "Andrew Johnson" <[email protected]>
Cc: Core-Talk <[email protected]>
Date: Tue, 30 Mar 2010 09:28:02 -0500
Andrew and others,
I’ve just found a bug in libCom/macLib.  I had a long command line (dbLoadRecords(…)) in a startup script, with several macros in it.  When the string is expanded it is more than 256 characters, so macEnvExpand has to go through an extra iteration.  When it calls free(dest), Windows (win32-x86 architecture) detects heap corruption.  It says that values past the end of “dest” have been modified.  This almost certainly means that macExpandString has written past the end of “dest”.  I suspect it is by 1 character.
To track it down I set handle->debug=3 in macEnvExpand, and got the following output.
dbLoadRecords("J:/epics/devel/areaDetector-1-6/ADApp/Db/NDOverlay.template",   "P=13SIM1:,R=Over1:, PORT=OVER1,ADDR=0,TIMEOUT=1")
macExpandString( J:/epics/devel/areaDetector-1-6/ADApp/Db/NDOverlay.template, maxlen = 256 )
trans-> entry = 0012FC60, level = 0, maxlen = 256, discard = F, rawval = J:/epics/devel/areaDetector-1-6/ADApp/Db/NDOverlay.template
<-trans level = 0, length =   59, value  = J:/epics/devel/areaDetector-1-6/ADApp/Db/NDOverlay.template
macExpandString() -> 59
macDeleteHandle()
macExpandString( dbLoadRecords("$(AREA_DETECTOR)/ADApp/Db/NDOverlayN.template","P=$(PREFIX),R=Over1:1:,NAME=ROI1, SHAPE=1,O=Over1:,XPOS=$(PREFIX)ROI1:MinX_RBV,YPOS=$(PREFIX)ROI1:MinY_RBV,XSIZE=$(PREFIX)ROI1:SizeX_RBV,YSIZE=$(PREFIX)ROI1:SizeY_RBV,PORT=OVER1,ADDR=0,TIMEOUT=1"), maxlen = 256 )
trans-> entry = 0012FD10, level = 0, maxlen = 256, discard = F, rawval = dbLoadRecords("$(AREA_DETECTOR)/ADApp/Db/NDOverlayN.template","P=$(PREFIX),R=Over1:1:,NAME=ROI1,   SHAPE=1,O=Over1:,XPOS=$(PREFIX)ROI1:MinX_RBV,YPOS=$(PREFIX)ROI1:MinY_RBV,XSIZE=$(PREFIX)ROI1:SizeX_RBV,YSIZE=$(PREFIX)ROI1:SizeY_RBV,PORT=OVER1,ADDR=0,TIMEOUT=1")
refer-> entry = 0012FD10, level = 0, maxlen = 241, rawval = $(AREA_DETECTOR)/ADApp/Db/NDOverlayN.template","P=$(PREFIX),R=Over1:1:,NAME=ROI1,   SHAPE=1,O=Over1:,XPOS=$(PREFIX)ROI1:MinX_RBV,YPOS=$(PREFIX)ROI1:MinY_RBV,XSIZE=$(PREFIX)ROI1:SizeX_RBV,YSIZE=$(PREFIX)ROI1:SizeY_RBV,POR
trans-> entry = 0012FD10, level = 1, maxlen = 256, discard = T, rawval = AREA_DETECTOR)/ADApp/Db/NDOverlayN.template","P=$(PREFIX),R=Over1:1:,NAME=ROI1,  SHAPE=1,O=Over1:,XPOS=$(PREFIX)ROI1:MinX_RBV,YPOS=$(PREFIX)ROI1:MinY_RBV,XSIZE=$(PREFIX)ROI1:SizeX_RBV,YSIZE=$(PREFIX)ROI1:SizeY_RBV,PORT=OVER1,ADDR=0,TIMEOUT=1")
<-trans level = 1, length =   13, value  = AREA_DETECTOR
lookup-> level = 0, name = AREA_DETECTOR, special = 0
<-lookup level = 0, name = AREA_DETECTOR, result = 010182A8
trans-> entry = 0012FD10, level = 1, maxlen = 241, discard = T, rawval = J:/epics/devel/areaDetector-1-6
<-trans level = 1, length =   31, value  = J:/epics/devel/areaDetector-1-6
<-refer level = 0, length =   31, value  = J:/epics/devel/areaDetector-1-6
refer-> entry = 0012FD10, level = 0, maxlen = 176, rawval = $(PREFIX),R=Over1:1:,NAME=ROI1,   SHAPE=1,O=Over1:,XPOS=$(PREFIX)ROI1:MinX_RBV,YPOS=$(PREFIX)ROI1:MinY_RBV,XSIZE=$(PREFIX)ROI1:SizeX_RBV,YSIZE=$(PREFIX)ROI1:SizeY_RBV,PORT=OVER1,ADDR=0,TIMEOUT=1")
trans-> entry = 0012FD10, level = 1, maxlen = 256, discard = T, rawval = PREFIX),R=Over1:1:,NAME=ROI1,   SHAPE=1,O=Over1:,XPOS=$(PREFIX)ROI1:MinX_RBV,YPOS=$(PREFIX)ROI1:MinY_RBV,XSIZE=$(PREFIX)ROI1:SizeX_RBV,YSIZE=$(PREFIX)ROI1:SizeY_RBV,PORT=OVER1,ADDR=0,TIMEOUT=1")
<-trans level = 1, length =    6, value  = PREFIX
lookup-> level = 0, name = PREFIX, special = 0
<-lookup level = 0, name = PREFIX, result = 01038698
trans-> entry = 0012FD10, level = 1, maxlen = 176, discard = T, rawval = 13SIM1:
<-trans level = 1, length =    7, value  = 13SIM1:
<-refer level = 0, length =    7, value  = 13SIM1:
refer-> entry = 0012FD10, level = 0, maxlen = 122, rawval = $(PREFIX)ROI1:MinX_RBV,YPOS=$(PREFIX)ROI1:MinY_RBV,XSIZE=$(PREFIX)ROI1:SizeX_RBV
trans-> entry = 0012FD10, level = 1, maxlen = 256, discard = T, rawval = PREFIX)ROI1:MinX_RBV,YPOS=$(PREFIX)ROI1:MinY_RBV,XSIZE=$(PREFIX)ROI1:SizeX_RBV,YSIZE=$(PREFIX)ROI1:SizeY_RBV,PORT=OVER1,ADDR=0,TIMEOUT=1")
trans-> entry = 0012FD10, level = 1, maxlen = 122, discard = T, rawval = 13SIM1:
refer-> entry = 0012FD10, level = 0, maxlen = 96, rawval = $(PREFIX)ROI1:MinY_RBV,XSIZE=$(PREFIX)ROI1:SizeX_RBV,YSIZE=$(PREFIX)ROI1:SizeY_RBV,PORT=OVER1,ADDR=0,TIMEOUT=1")
trans-> entry = 0012FD10, level = 1, maxlen = 256, discard = T, rawval = PREFIX)ROI1:MinY_RBV,XSIZE=$(PREFIX)ROI1:SizeX_RBV,YSIZE=$(PREFIX)ROI1:SizeY_RBV,PORT=OVER1,ADDR=0,TIMEOUT=1")
trans-> entry = 0012FD10, level = 1, maxlen = 96, discard = T, rawval = 13SIM1:
refer-> entry = 0012FD10, level = 0, maxlen = 69, rawval = $(PREFIX)ROI1:SizeX_RBV,YSIZE=$(PREFIX)ROI1:SizeY_RBV,PORT=OVER1,ADDR=0,TIMEOUT=1")
trans-> entry = 0012FD10, level = 1, maxlen = 256, discard = T, rawval = PREFIX)ROI1:SizeX_RBV,YSIZE=$(PREFIX)ROI1:SizeY_RBV,PORT=OVER1,ADDR=0,TIMEOUT=1")
trans-> entry = 0012FD10, level = 1, maxlen = 69, discard = T, rawval = 13SIM1:
refer-> entry = 0012FD10, level = 0, maxlen = 41, rawval = $(PREFIX)ROI1:SizeY_RBV,PORT=OVER1,ADDR=0,TIMEOUT=1")
trans-> entry = 0012FD10, level = 1, maxlen = 256, discard = T, rawval = PREFIX)ROI1:SizeY_RBV,PORT=OVER1,ADDR=0,TIMEOUT=1")
trans-> entry = 0012FD10, level = 1, maxlen = 41, discard = T, rawval = 13SIM1:
<-trans level = 0, length =  256, value  = dbLoadRecords("J:/epics/devel/areaDetector-1-6/ADApp/Db/NDOverlayN.template","P=13SIM1:,R=Over1:1:,NAME=ROI1,   SHAPE=1,O=Over1:,XPOS=13SIM1:ROI1:MinX_RBV,YPOS=13SIM1:ROI1:MinY_RBV,XSIZE=13SIM1:ROI1:SizeX_RBV,YSIZE=13SIM1:ROI1:SizeY_RBV,
PORT=OVER1,ADDR=0,T
macExpandString() -> 256
I have not digested the output.  To try to work around the problem, I modified the line:
        n = macExpandString(handle, str, dest, destCapacity);
to be
        n = macExpandString(handle, str, dest, destCapacity-1);
i.e. to tell macExpandString that the buffer is 1 character smaller than it really is.
Index: macLib/macEnv.c
RCS file: /net/phoebus/epicsmgr/cvsroot/epics/base/src/libCom/macLib/macEnv.c,v
retrieving revision 1.2.2.6
diff -u -r1.2.2.6 macEnv.c
--- macLib/macEnv.c     23 Apr 2009 18:49:39 -0000      1.2.2.6
+++ macLib/macEnv.c     30 Mar 2010 14:23:26 -0000
@@ -38,7 +38,7 @@
         free(dest);
         dest = mallocMustSucceed(destCapacity, "macEnvExpand");
-        n = macExpandString(handle, str, dest, destCapacity);
+        n = macExpandString(handle, str, dest, destCapacity-1);
     } while (n >= (destCapacity - 1));
     if (n < 0) {
That fixed the problem, but I think that probably the correct solution is to find where macExpandString is writing past the end of dest and fixing that.
Re: Bug in macLib Andrew Johnson
Prev: Re: [Bug 541396] Re: initialize VAL of an mbbi/o record with a string Benjamin Franksen
Next: Re: Bug in macLib Andrew Johnson
Index: 2002  2003  2004  2005  2006  2007  2008  2009  <20102011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: [Bug 541396] Re: initialize VAL of an mbbi/o record with a string Andrew Johnson
