2002  2003  2004  2005  2006  2007  2008  2009  <20102011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 2002  2003  2004  2005  2006  2007  2008  2009  <20102011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: [Question #110395]: push fails?
To: [email protected]
Date: Mon, 10 May 2010 05:18:25 -0000
New question #110395 on EPICS Base:
https://answers.launchpad.net/epics-base/+question/110395
I dont know if this is normal but will have to discard the work I did this weekend because a push failed.
Run command: bzr push --directory C:/epicsInBazaar/cvs-trunk/trunk --no-strict
Using saved push location: http://bazaar.launchpad.net/~epics-core/epics-base/cvs-trunk/
bzr: ERROR: Cannot lock LockDir(http://bazaar.launchpad.net/~epics-core/epics-base/cvs-trunk/.bzr/branch/lock): Transport operation not possible: http does not support mkdir()
You received this question notification because you are a member of
EPICS Core Developers, which is an answer contact for EPICS Base.
Re: [Question #110395]: push fails? Ralph Lange
Prev: Re: Experimental Sequencer Release Benjamin Franksen
Next: Re: [Question #110395]: push fails? Ralph Lange
Index: 2002  2003  2004  2005  2006  2007  2008  2009  <20102011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: RE: epicsEvent::invalidSemaphore exception in timerQueue Jeff Hill
