Subject: |
RE: [Merge] lp:~michael-abbott/epics-base/dynamic-array intolp:epics-base |
<[email protected]> |
To: |
Date: |
Thu, 24 Jun 2010 09:54:51 +0100 |
Jeff,
You wrote:
> Please add a client side initiated regression test to
> acctst.c that verifies that the new feature works properly.
> Sorry, that acctst.c is a messy code for certain but it does
> serve its purpose of preventing introduction of bugs that
> have been seen before. This will also have the benefit of not
> allowing my neglect of parallel changes for these features in
> the new server :^). Also, running acctst might even help to
> test the features you have added.
I don't think that acctst is a valid epics test harness. I suggest we
also look at turning it into one so that it is run with make runtests
(and also with our automated test system). Is this a sensible idea?
Cheers,
Nick Rees
Principal Software Engineer Phone: +44 (0)1235-778430
Diamond Light Source Fax: +44 (0)1235-446713
> -----Original Message-----
> From: [email protected]
> [mailto:[email protected]] On Behalf Of Jeff Hill
> Sent: 22 June 2010 21:56
> To: [email protected]
> Subject: Re: [Merge]
> Hi Michael,
> Thanks for your help.
> changes in ca/caProto.h
> > +# define CA_V412(MINOR) ((MINOR)>=12u) /* Allow zero length in
> > requests. */
> The following is what I have on the Bazaar branch which was
> based on the cvs main trunk (this is where I have always
> added new features in the past so that I didn't mix together
> patch level changes in the R3.14 branch (i.e. fixes) with
> feature upgrades).
> # define CA_V412(MINOR) ((MINOR)>=12u) /* TCP-based search
> requests */
> # define CA_V413(MINOR) ((MINOR)>=13u) /* channel
> connectivity response messages */
> So we have some conflicts with the new TCP search protocol
> and some capabilities I have in the new server which allow
> the service to report the current state of the connectivity
> it has with its channel.
> I propose the following based on the order (in time) that
> each upgrade might be installed into base (the TCP based
> search request changes were completed a long time ago):
> o V412 - TCP based search requests
> o V413 - dynamic payload sized subscription / get callback
> response message
> o V414 - connectivity response messages
> I am confused about the purpose of this change (presumably
> the old code was safer because the client code's compiler can
> check for access past the end of the array)?
> diff --git a/src/ca/db_access.h b/src/ca/db_access.h
> -epicsShareExtern const unsigned short dbr_size[LAST_BUFFER_TYPE+1];
> +epicsShareExtern const unsigned short dbr_size[];
> /* size for each type's value - array indexed by the DBR_
> type code */
> dbr_value_size[LAST_BUFFER_TYPE+1];
> +epicsShareExtern const unsigned short dbr_value_size[];
> Changes to rssrv/camessage.c
> I am a bit concerned that if for whatever reason
> db_get_field_and_count returns an item_count greater than
> requested then we could have data_size greater than
> payload_size which could cause the unsigned subtract to
> overflow here. That could cause memset to copy many (way too
> many) elements which would almost certainly profoundly crash
> the IOC. Can we afford the risk? I would add an "if
> (payload_size - data_size)" sanity check here. Yes, nannying
> but robust.
> returns data_size greater
> + memset(
> + (char *) pPayload + data_size, 0,
> payload_size - data_size);
> Otherwise, I did finally have a very close look today, and it
> looks good.
> https://code.launchpad.net/~michael-abbott/epics-base/dynamic-
> array/+merge/26796
> Your team EPICS Core Developers is requested to review the
> proposed merge of lp:~michael-abbott/epics-base/dynamic-array
> into lp:epics-base.
- Re: [Merge] lp:~michael-abbott/epics-base/dynamic-array intolp:epics-base Ralph Lange
- RE: [Merge] lp:~michael-abbott/epics-base/dynamic-array intolp:epics-base Jeff Hill
- [Merge] lp:~michael-abbott/epics-base/dynamic-array into lp:epics-base Michael Abbott
- Re: [Merge] lp:~michael-abbott/epics-base/dynamic-array into lp:epics-base Jeff Hill
Merges: 3.14.12 vs 3.15 Andrew Johnson
RE: Merges: 3.14.12 vs 3.15 nick.rees
<2010>
2025
2026
RE: [Merge] lp:~michael-abbott/epics-base/dynamic-array intolp:epics-base Michael Abbott
<2010>
2025
2026
