2002  2003  2004  2005  2006  2007  2008  2009  <20102011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 2002  2003  2004  2005  2006  2007  2008  2009  <20102011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: build error on R3.14 trunk
To: [email protected]
Date: Fri, 13 Aug 2010 17:49:27 -0500
On Friday 13 August 2010 17:10:49 Jeff Hill wrote:
> FWIW, I see the following error when building the R3.14 trunk on windows.
> cl -c               /nologo /D__STDC__=0 /D_CRT_SECURE_NO_DEPRECATE
> /D_CRT_NONST
> DC_NO_DEPRECATE   /Zi /RTCsu   /W3 /w44355       /MDd     -I.
> -I..\\O.Common -I.
>  -I.. -I..\\..\\..\\..\\include\\os\\WIN32 -I..\\..\\..\\..\\include
> buckTest.c
> buckTest.c
> ..\buckTest.c(12) : fatal error C1083: Cannot open include file:
> 'unistd.h': No such file or directory
I see from the log that unistd.h was added by Eric, apparently to get this to
build on RTEMS 4.10, but when I remove it I see no errors or warnings with
RTEMS 4.10 or 4.9.2.  I am getting a load of *other* build failures with 4.10,
but that's probably just our configuration here (which is evidently missing
Eric's tender ministrations).
I propose to delete unistd.h again from buckTest.c unless someone can explain
why it's needed.
- Andrew
The best FOSS code is written to be read by other humans -- Harald Welte
Re: build error on R3.14 trunk Eric Norum
build error on R3.14 trunk Jeff Hill
Prev: build error on R3.14 trunk Jeff Hill
Next: Re: build error on R3.14 trunk Eric Norum
Index: 2002  2003  2004  2005  2006  2007  2008  2009  <20102011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
